Question about Audiovox D1812 Portable DVD Player
Emerson PDE-2717 Portable DVD Player - worked great for a few months but now just says 'Bad Disc' even when using discs that work in other players.
I've used cotton/alcohol to lightly clean the lens. I've tried a DVD lens cleaner disc. I've held the 'button' down to watch as it runs and the disc spins, the laser comes on and seems to focus (wide then narrow) and moves along the disc. But it does that a few times and then parks itself and displays 'Bad Disc' on the screen. Any other suggestions of things to try before I scrap this thing? Thanks!
  • Anonymous Dec 29, 2007
    worked great for a few months but now just says 'Bad Disc' even when using discs that work in other players.tries to focus and track but wont read
I had same problem, took the back cover off. two scews that are right were the ribbon connects to the read head I believe are potentiometers adjusted with eyeglass screw driver a couple attempts it worked. I also disconnected the plug for external battery and left unpluged since I don't use battery
Posted on Dec 29, 2007
Connect the DVD player and while it is off, press for 5-10 seconds the 'A-B' button. This will help clear the 'Bad Disc' memory. Enjoy!
Posted on Sep 29, 2007
SOURCE:
Does not spin dvd
Sometimes the brushless motor driver circuit fails. Rarely does the motor itself go bad. On some models, if the the laser diode is too weak to read the disc, the player will not bother to spin it. It won't spin so a lens cleaner disc won't work You can try to take it apart and clean the tiny lens. Don't use alcohol. Windex and a Q-tip works great to remove grease and dirt. Don't buff it hard. Just wipe lightly a few times and look at it at an angle to make sure it is shiny, not hazy. Almost all of these are not an economically viable repair. If cleaning the lens does not help, you are looking at another portable player.
Sep 02, 2012 | kawasaki PVS-10921 Portable DVD Player
Tip
Player reading invalid disc and disc is not spinning
My dual screen dvd player was reading invalid disc and disc was not spinning. Took player completely apart and white gears had dirt in them. This was preventing the player from spinning. Used dust remover and cleaned the whole inside and now it works great.
on Sep 01, 2008 | Durabrand DUR7 Portable DVD Player
Philips PET710 DVD player shows 'no disc' when disc inserted
I have the same problem with my portable dvd player and found that cleaning the lens of the player using a non-alcolhol wet nap for cleaning eye glasses worked well. I also found the rail that the optics runs along while playing needed a very small amount of silicone greese applied using a Q-tip. You may find that the optic unit may be "stuck" somewhat but can be resolved by gently moving the optic along its guide using a finger.
This changed my unit from not working at all, to working intermittantly sometimes having to vary the player on and off to recongnise the disc. Hope this works
Jul 28, 2009 | Philips PET710 Portable DVD Player
Portable dvd player keeps saying bad disc
try cleaning the lens with a lens cleaner cd, if this doesn't work the lens itself is scratched or faulty and you will need to buy another dvd player
Nov 27, 2008 | Televison & Video
Polaroid Model pdm 2727 2 7inch Wal Mart Purchase $185.00 (HELP PLEASE)
You might try gently cleaning the laser eye with soft dry Q-tip. Other wise the laser will probably need replacing. I repair and sell portable DVD players.
May 15, 2008 | Polaroid 7" Two-Screen Portable DVD Player
Emerson PDE 2717
I also needed a new screen to screen power cord. Call 1-866-553-7521 and give them the model # PDE 2717. Ask specifically for the screen to screen power cord because the first cord the see when they do a look-up is the car to screen cord. The cost was $6.00 but adding in shipping brought the total to $15.99. Expect the delivery in 7 to 10 business days. Thanks and enjoy!
Apr 04, 2008 | Car Audio & Video
Emerson PDE-2717 portable DVD won't read disc
i believe it is related to power as this issue started on one of these after turning on both screens. i am still dealing with millenium 3000 over a purchase of the same unit. i am going to be trying a 4th unit 'when new stock arrives' but i doubt it.
Jan 15, 2008 | Televison & Video
Emerson PDE-2725N DVD player
My PDE 2625n worked on the way to Mimi's and starting on the way home it displayed "Disk Loading..." then errord out with "Bad Disk". I dug through the internet and over 3 days found the answer.
Your laser is tired. Since the DVD player is cheap, replacing it is not worth the $$. Fix it! Remove the back cover (about 10 small phillips screws). It is important to know that their is a back plate AND a back panel; remove the PLATE which should have a model number sticker.
Now you should see a circut board with a set of polished rails which holds the read head. On the read head (by a ribbon cable ) are two very, very, very small flat blade POT screws. These control the amount of power sent to the laser. Turn the right most one CLOCKWISE about a 1/8 to 1/4 turn.
You can test your handy work by popping in a DVD while the cover is off and seeing if it loads. If all is ok, put it back together. If not turn it a little more. I used a car battery charger to run my test since it's about 25 degrees outside.
Be aware the more power sent to the laser, the faster it burns out (according to my research). By feeling is the DVD player is broke, so what? Am I going to break it? What the hell;) and I cranked away.
BTW I just got this fixed this morning. My kids are screaming with joy for DVD's in the car again! I'm thrilled that I don't have to spend $100 or more to replace this unit.
Cheers!
Ap
Nov 16, 2007 | Car Audio & Video
Disk is not spinning in emerson portable dvd
if the disc doesn't spin, it sounds like a bad motor. can you hear the laser adjust? if you do, then it's probably a dead motor, if you can't hear that laser adjust at all, and the motor doesn't spin at all, the connection might have come undone(they both share a connection)
Nov 12, 2007 | Zenith DVP615 Portable DVD Player
Audiovox D1812 Portable DVD Player Logo
916 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
