Question about LG LHD45EL Dehumidifier
Error ch01 is shown?
My dehumidifier bucket is clean and empty but when I go to turn in back on I get an error ch01?
  • Anonymous May 21, 2009
    'ERROR CHOI IS SHOWN AND BUCKET FULL LITE BLINKS'
  • biericks May 26, 2009
    Bucket is empty and cho1 error code shows with the Bucket Full light blinking.
I decided to phoned LG customer service directly. They informed me that my dehumidifier comes with a 5 year warranty. They gave me a ph# to call of a dealer located in my area that will fix my problem at no charge. They were very helpful.
Posted on Apr 19, 2009
Says bucket full and it is empty
There is a float switch somewhere to measure the level of water in the bucket. That switch is out of position or broken. This can happen if you are not careful removing and re-installing the bucket. Look at the area around the bucket and you should be able to find and fix the switch. Make sure the power is off when you are doing this.
Nov 13, 2013 | LG LD450EAL 45 Pint Dehumidifier
It says CH01 and will not turn on.
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Sep 06, 2011 | LG LHD45EL Dehumidifier
My LG dehumidifier has an error display CH01 and says it has a full bucket when I never use the bucket. I purchased the sensor part from Appliance Factory parts and find it is not quite as easy to install...
Hi
If this is the same as the original part then you can follow the wiring through the casing, sometimes you can tie a piece of thin cord to the cables as you pull them through and then use this to pull the new cables back.
Do you have the bucket, as lots of these sensors need to be plugged into the bucket to operate properly. Even if you are using the drain hose.
Another thing worth noting is that often when the sensor reads a fault it can be just dirt or slime on the sensor, a good clean with an old toothbrush and warm soapy water can often acheive excellent results.
Hope this helps
Regards
Gordon
Apr 17, 2011 | LG LHD45EL Dehumidifier
Even though I have emptied the bucket the bucket full light will not turn off and the dehumidifier will not reset. I tried unplugging the unit but when I plug it back in it still says bucket full
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Aug 29, 2010 | Haier 45-Pint Dehumidifier
Our LG LHD45EL dehumidifier stopped working. The bucket full light flashes, though the bucket is empty and the filters clean. The display shows CH01. The manual does not say what CH01 means. Any...
I don't know what CHO1 is either! My husband and I had the same problem a couple years ago. We just ended up buying a new one.
http://www.donmurraysbobcatandtipperhire.com.au
Jul 22, 2010 | LG LHD45EL Dehumidifier
Empty bucket light is on and dehumidifier will not run
The float switch for the condensate reservoir (bucket) is malfunctioning.
It's sending a false signal that the bucket is full.
Maybe just stuck and needs cleaning or it may have failed.
May 31, 2009 | Whirlpool AD65USL / AD65USM Dehumidifier
CH1 IS SHOWN AS WELL AS THE BUCKET FULL LIGHT
I have a LG model LHD65EBL that first started icing up along the top edge during humid days. After several months of this, it finally stopped working and displayed CH01 with the bucket full indicator flashing.
I took apart the dehumidifier, removed the temperature sensor from the coil and rubbed it between my fingers. I then plugged in the unit and it started right up, confirming either a sensor or other circuit problem related to that sensor. For my model unit, I ordered sensor assembly #6877A30013L from RepairClinic.com for $21.75 + shipping.
When I received the assembly, I measured the new and old sensor with an ohm meter: new sensor = 5.5KOhms, old, defective sensor = 5.34KOhms. I installed the new sensor assembly and the unit is working fine.
Just because the bucket full indicator is flashing along with an error code does not mean there is a problem with the bucket full switch.
Dec 17, 2007 | LG LD65EL Dehumidifier
LG LHD45EL Dehumidifier Logo
591 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
