Question about Dell E153FP 15" LCD Monitor
? dell monitor to compac ?
Can;t get signal to the monitor what ca i do
  • 3,940 Answers
Since you didn't post the Model of the Compac, All I can give you is some general information.
1st, does the monitor work on another system? (Is it a known good monitor?)
If it works on another system, then the issue is with the system, or the connection to the system.
Check the connection to the system (Some systems have both on-board and expansion video cards, if the system has an expansion card the on-board video is usually disabled)
Make sure the cable is correctly connected to both the system and the monitor and no pins are bent.
If the monitor has not been tested, then try connecting it to a system you know that works.
Posted on Apr 19, 2009
Why Dell icon flashes continuously on the screen when switched on in Dell IN1930f Monitor?
Press the Menu button on the monitor.
  • If the menu comes up, you've got a problem with the video signal.
  • If no menu appears, then there's something gone pear-shaped inside the monitor, possibly the power supply.
If you've still got the documentation for it, check the troubleshooting guide, usually found at the end of the manual.
Sep 25, 2016 | Dell Computers & Internet
Dell PC Desktops not sending signal to the monitor
hello,
If you dont get a signal to the monitor check these two situations:
1.check if the graphic card is properly inserted(pul it out and then back again)
2.check if the monitor in plug in if yes try to test the monitor maybe it's broken
Nov 05, 2012 | Dell GX745 Refurbished Desktop PC
Can I use a Dell 922 printer with my Compac Presario CQ61 computer?
You should have no problems using this printer with your computer provided you install the printer driver on your computer.
You can download the Dell printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=3A943AE039242E89E040A68F5B2854C9&journalid=803559AE24446852E040AC0A66E95D38&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=#Issue0_3
Oct 21, 2012 | Dell Office Equipment & Supplies
My desktop monitor direct go in power save mode.so please solve it as soon as possible its urgent
power save mode indicates no input signal. Check the input signal with a known good monitor. if the signal is good then dell monitor is faulty. Power cycle (unplug the power then plug it back in) the monitor to reset to factory and if it still goes directly into power save mode the unit is faulty.
May 01, 2011 | Dell E1709W Monitor
Down load to compac computer isn't accepted
In the control panel, uninstall H.P and use software from Dell and install new printer software. Make sure you uninstall ALL H.P. first.
Jul 09, 2010 | Dell 924 All-in-One InkJet Printer
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
Whenever i turn on my pc it says no input signal.i dont know whats wrong with it.is it the motherboard or the hard drive?
When you power up the cpu check your smps is working?
Then check num lock key on key bord if it is on and off when you press numlock then your cpu gives dispaly to monitor ok.
but if it not constant on or off no change when you press num lock key then you have to open cpu cabinet.
Refix RAM memory .
Clean dust from motherbord chipset.
Pull out cmos cell for 15 minutes so bios settings are reset to defaults.
then check.
refix all connection to mothebord like ATX power supply from smps.
Jul 23, 2009 | HP Pavilion a1540n PC Desktop
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
I-INC monitor to use with my Dell Laptop, no signal to monitor?
When Windows logo disappear on the I-INC, do you still see it on the Laptop monitor?
All laptops have function keys to switch the screen between the external monitor (I-INC) and laptop monitor. On your laptop, it is Fn+F8 key. Press them once and wait for 3 seconds, it will switch the image between 2 monitors (external monitor ONLY, laptop monitor ONLY, and both).
During start-up, do not close the laptop cover. Because it may put your laptop into a stand-by mode and turn off the screen. You need to modify this Power Option setting within the Control Panel.
Mar 28, 2009 | Dell Inspiron 1100 Notebook
Emachine monitor with a HP computer
i am trying to hook up a emachine monitor to my compac computer but the monitor will not come on there is another wire coming off the part that hooks in the compac but there is nowhere to hook it can you help me?
Oct 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Dell E153FP 15" LCD Monitor Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
