Question about Pool & Spa
Manual for triton 230 model 32024-1 pool pump, please.
We located the manual so problem solved!
Posted on Apr 20, 2009
I need a pump ours went out HAYWARD POOL MODEL T63CXDCY-1652RPM 3450 VOLTS 208-230/115 HZ60MFG#MH07 C
go online to buy pool parts on line dot com match up your pump they have free shipping sometimes they helped me
Sep 10, 2014 | Hayward Pool & Spa
I have a new C48K2N143B1 that I'm replacing the same model that has quit. It came configured for 230 and I switched the tab for 120. Wired everything the same as the old motor and it keeps tripping the...
make sure you have clean source voltage coming in like a knicked wire touching the case, also make sure you dont have the hot wire leads touching the frame or something else
Jun 19, 2014 | Hayward 3/4hp Super Pump Inground Pool...
I cant see the way to change 115/230 starite pool pump 1.5 hp
look on the motor ID plate it has a diagram how to set voltage
Jun 30, 2012 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Pump trips circuit breaker/where can i get a wiring diagram for this pump?
The owners manual does not have information on the pumps. You would need to get the model information off of the motor, and request that information from the manufacturer.
Otherwise, all motors have the wiring diagram right on the side of them.
Jun 09, 2011 | Hayward 3/4hp Super Pump Inground Pool...
I have a proline pool pump model # SD-15-1N11CC and it worked fine until I back washed my pool and now it stopped working. It makes a humming noise and nothing else.
C. MOTOR HUMS, BUT DOES NOT START—
Check for:
1. Centrifugal switch stuck in open position.or if capacitator start could be bad capacitator. Possible loose connection.
2. Binding of motor shaft. (something stuck in impeller) Does motor turn free. IF not check for jamed impeller. If it she sp2605x7 you can view a manual here:
http://www.haywardnet.com/products/Manuals/pdfs/manual113.pdf
Aug 17, 2010 | Hayward 3/4hp Super Pump Inground Pool...
I have a sta rite 1 hp 115/230 motor i cant find where the white wire goes do you have a diagram
I assume you mean the white wire under the rear motor cover? If so Sta-Rite puts a wiring diagram inside this back cover. Hopefully it is still intact for you. Depending on your model and if it is wired for 115vac or 220vac will make a difference. I would suggest you go to the link I attached and look up your manual. The manual will have the wiring diagram for you.
http://www.starite.com/
I hope this helps you out. Please rate my response. thanks
Jun 17, 2010 | Sta Rite Sta - Rite 1hp Dura - Glas...
I'd like to know how to change a 115/230 volt pool pump motor to run on 115 volts after I've already change to internal possition to 115 volts
IF YOU SEE ON THE LABEL ON THE MOTOR HOW TO CHANGE FROM HI - LO VOLTS . THATS ALL YA GOT TO DO ..THE WIRES HOOK UP NORMALY
May 21, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Pool & Spa Logo
114 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
