Question about Dell Inspiron 6000 Notebook
Blank screen Once I switch on my Inspiron 6000 notebook,it leaves with desktop screen without desktop icons and taskbar. When I pressed alt+ cntrl+delete it shows that task manager is in disable mode. Please help me out from this issue. Thanks Umesh
    Sergeant:
    New Friend:
  • Dell Expert
  • 124 Answers
As soon as you start the computer, keep pressing the DEL key, or the indicated key on the first screen it will say somewhere (at the top or bottom usually) 'Press ... to enter setup/bios' press that.
go through the menus and find something simular to 'boot sequance' and change the 1st to your HDD and 2nd to the DVD drive. save and exit (F10 key)
this should now boot using the HDD, if you have any other drives connected like a MP3 player, flash drive, phone or something that has storage space disconnect it.
IF YOU GE THE WINDOWS LOAD SCREEN
if you get the windows load screen and then the flashing cursor, keep pressing the F8 key on startup, from the list select 'last known configuration that worked' and it should start up.
Edit_
To update your question, rather than ask another, under your question click on 'Edit' and then Add more details'
Posted on Mar 26, 2015
    Sergeant:
  • 457 Answers
Right mouse click on the desktop now show the desktop icons? was this ok?
Posted on Sep 18, 2007
SOURCE:
Sideway screen INSPIRON mini how do I fix it
Changing the screen orientation of your Windows display can make your screen rotate at a 90-degree, 180-degree and 270-degree angle. By default, Windows operating systems do not come with a built-in mechanism to change the screen's orientation. Certain graphics boards, such as Intel, utilize hot keys to change the screen orientation. If the hot keys do not work on your computer, a program can be installed to create shortcuts that change the screen's orientation. One such program that is Windows compatible is called "iRotate," which is available to download for free.
Turn your computer on and wait for it to load. Once your computer finishes loading, make sure any open programs are minimized or closed. Press and hold the "Ctrl" and "Alt" keys on your keyboard. Press the corresponding arrow key on your keyboard for the direction to which you want to orient your screen. Press and hold the "Ctrl," "Alt" and up directional arrow key to return the screen to its regular orientation. iRotate Application Open the iRotate download site (see Bottom of page.) in your web browser. Click on the blue download link on the left-hand side of the page. The download link contains the text "iRotate" and has an icon of a floppy disc. Save the file to your computer. Open the iRotate file and follow the on-screen prompts to install the program to your computer. You can choose whether or not to put a shortcut on your desktop, place a folder for the program in your "Start" menu or automatically run the program after it finishes installing itself. Right-click on the iRotate icon in your taskbar. The iRotate icon is a blue rectangle that will display information about your graphic properties when you hover your mouse over the icon. Select a screen orientation from the drop-down menu. You can choose a 90-degree, 180-degree or 270-degree rotation. The "Normal Landscape" option returns your screen to its default orientation. iRotate
http://www.entechtaiwan.com/util/irotate.shtm
Mar 01, 2013 | Dell Inspiron Mini 10 Notebook
How to reset lost password?
What OS are you having?
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Reset
Hope you can reset windows password soon.
Jul 09, 2012 | Dell Inspiron 8600 Notebook
I have a Compac computer that has Windows XP installed (SP2), when I start up the computer, the Windows XP will not run correctly. Once it seems to be opening Windows, my computer screen just looks blank...
When you are on the blank screen try to press CTRL+ALT+DEL on your keyboard at the same time. it should bring up the task manager window. now, click on FILE > New Task Run > Type in EXPLORER.EXE and press Ok. it should show you your Taskbar, desktop wallpaper, desktop icons
Oct 01, 2010 | Computers & Internet
My dell inspiron mini 10 bootes up to the main sceen but no icons nor start button appear.. please help
ok try starting in safe mode, keep pressing f8 on startup till menu appears, then run system restore if safe mode works
Aug 30, 2010 | Dell Inspiron Mini 10 Notebook
Blank screen
This sounds like corrupted Windows and will require a software reload, however you might try this to make things easier in the mean time... (written for XP)
Right click in the taskbar (usually at the bottom of the screen). If 'Lock the Taskbar' is checked, click it to uncheck. Next, click 'toolbars' and 'Desktop'. This should put a new toolbar in your taskbar called Desktop. You should be able to push this all the way to the right. Now when you want to access the desktop Icons, they will be available at the double arrows on the right of the word Desktop. I keep mine this way all the time so I can access stuff on the desktop even when it is covered with open windows.
May 06, 2010 | Tablets & eReaders
Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Apr 03, 2009 | Dell Inspiron 6000 Notebook
ThinkPad T60 Desktop Not Restored After Hibernation/Standby
there is something that runs most of the interface between the user and the computer it is called explorer.exe to get the task manager open, you can try pressing CTRL+Shift+Delete another alternative is to do an OS reinstallation.
To get explorer.exe
1) press Ctrl+Alt+Delete; in unsuccessful try Ctrl+****+Delete
2) if task manager opens click on 'New Task..." (if task manager does not open, consider reinstalling your OS or simply don't go into standby/hibernate)
3) Once you get the New Task dialog box, type explorer.exe or C:/Windows/explorer.exe
Jan 01, 2009 | IBM ThinkPad T22 2647 Notebook
Blank screen.
"Download TweakUI from the link below, install it, click Start>Run, and type in TWEAKUI now click ok, in the window that pops up, click on Pepair, now click on the down arrow in the right hand pane, make sure Rebuild Icons is selected, now click Repair Now, Click OK, then Reboot, al should be well then." http://download.microsoft.com/download/f/c/a/fca6767b-9ed9-45a6-b352-839afb2a2679/TweakUiPowertoySetup.exe
Jun 11, 2007 | Dell Inspiron 6000 Notebook
Blank screen
Try doing a control+alt+del and the selecting New Task then type explorer. This should bring up your normal windows desktop and icons, etc.
Dell Inspiron 6000 Notebook Logo
110 people viewed this question
Ekse
Clive
Clive
