Standard Televisions
Problem for Standard Televisions
Generic problem for all Standard Televisions
No raster no audio,Zenith SJ 2065S5
By Goodwrench on Sep 18, 2007
No Raster no audio.The horizontal output transistor gets very hot..Please advise
Solution #1
posted on Sep 19, 2007
Somewhat Helpful)
modern
Rank: Wiz
Rating: 80%, 660 votes
as horizontal transistor gets very hot so no eht so no raster &no sound due to nosupply to vif & tuner.
as hor output is getting hot please isolate supply to hor. section & check power supply output is ok as due to high voltage h/outout may get hot & demaged.
if supply is ok check for leaky or short parts in hor output.
1 hor. output transistor itself if it is replaced that may not be of proper matching.
2 diode& cap.in eht section.
3 clean print near eht.
4 moisture near yoke due to rain in rainy season only. so keep it hot for few hours.
5 at last if all are ok
eht or fly back transformer.
re connect power to hor output after rectification
Was this helpful?
Yes
No
Solution #2
posted on Sep 20, 2007
Not Rated)
guly
Rank: Wiz
Rating: 80%, 100 votes
1. the tester set to 250 up dc vlts
2. the neg - grn of the tester put the grn - in the picture tube
3 the pos.+ of the tester test to colector of the output transistor center legs the (H OUT)
4.look for the 120 or 130 vltsDC if the supply is normal. set the tester to 10 AC vlts test the pos.+ of the tester to BASE. and power on if no supply for AC. no oscillation check the jungle IC good luck
Was this helpful?
Yes
No
Popular Solutions for Standard Televisions
Questions and Unsolved Problems for Standard Televisions
Answer
I would like to connect TV (Sony Trinitron KV-24FS100) to my Sony Receiver (STR-D865). Can you help... (More)
Answer
The display on the screen will not fit fully on the screen, meaning that I am loosing the sides of... (More)
Answer
The timer button on the front panel is blinking red and will not allow me to power on the TV. What... (More)
Answer
No sound from my RCA 25 inch Xl100 TV (Model F25216bc, chassis CTC185ab3). Good pic but no sound.... (More)
Answer
My Sony KP-57WS520 will not power on and gets 10 blinking lights on the stand by mode
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
