Question about Hitachi 42PD7200 42 in. HD-Ready Plasma Television
I can't find UHF channle 36
I HAVE A HITACHI {MODLE P42hO1AU} PLASMA TV. I ALSO HAVE A X-BOX. FOR MY X-BOX I BOURGHT A RF ADAPTER. I PUT THE PLUGS IN THE RIGHT PLACES BUT IT DIDN'T WORK. I READ IT AGAIN AND IT SIAD TO CHANGE THE CHANNLE TO UHF CHANNLE 36 BUT I CAN'T FIND IT . PLEASE HELP ME !!
  • jeremy_doowa Jun 10, 2009
    I had no idear. tell you guys your awsome i love you
    Problem Solver:
  • 4 Answers
Turn plasma to analoque tv tuner auto search while xbox is connected and turned on. Auto tune will pick up uhf 36 channel .Flick chanelstill xbox chanel is viewable
Posted on Apr 19, 2009
You guys are the best i mean i got it all don in 3 min. you guys are unbleaveable.
thanks heaps:-)
jeremy
Posted on Jun 10, 2009
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
I do not know how to wire the nintendo nes to the tv
hello kenny
you need an antenna cable or also called rf cable, one end goes to nes console and other and to tv's rf input, then you have to search tvs tuner for right channel (generally UHF channel 36 is standard).
regards
Feb 19, 2011 | Computers & Internet
I don't see the cable connection on the TV. Is there an adapter for this?
This TV doesn't have a tuner and thus no RF (coax) input. It should be connected to a set top box by component, composite or S-video cables. Component video (with three RCA video plugs on each end) will provide the best signal (a separate cable with two plugs on each end carries the audio).
I wish that I could be of more help.
Sep 30, 2010 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Hitachi Plasma TV _ AV300E
Depending on the way you hook up the media or cable box, this is what you look for, if you are in the video area then look for V1, V2, V3 or the right one if you are on the RF connection then it also has an A and B side. Try each
Feb 27, 2009 | Hitachi 42PD3000 42 in. Plasma Television
DVD to TV - can't connect. No inputs on the actual TV
You could buy a RF Modulator, into which you can Input the 3 cables (Video, Audio Right and audio Left) and the Modulator will make it into a single RF signal, which can be tuned by the TV. RF Modulators are generally set at UHF Channel 36 by Default. One of the easisst available is the Rabbit Ears Modulator, which "transmits' the signal wirelessly to the TV. Not more than 15-20$
Nov 29, 2008 | RCA 32F531T 32" TV
JVC HR-D337MS Multisystem VCR - NO SIGNAL The only information I could find on the internet was it was worth $450.00 in 1991. i hooked up the RF out to RF on the TV in. Pushed play on the VCR. No signal....
Connect RF out of VCR to Antenna IN of TV. There should be a Test Signal switch at rear of VCR. Push it to ON. JVC VCRs generally generate a RF signal in the UHF band, around channel 36. Scan all channels on your TV, you should gete a Test signal of 2 parrallel black bars around channel 36. That is the Channel on which you can view tapes. Switch off 'Test signal' at rear of VCR, and press play. you should be able to watch your tape.
Jul 14, 2008 | Televison & Video
Older hitachi TV
Check the menu and check to see if it's setup for cable and not antenna. Also see if there is an auto program function in the menu.
Apr 23, 2008 | Televison & Video
Tv want get the low channles when i search for channels
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Nov 22, 2007 | GE 31GT740 31" TV
Hitachi 42PD7200 42 in. HD-Ready Plasma Television Logo
395 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
