Question about Kenmore Washing Machines
NO HEAT in stacked Kenmore dryer
Kenmore stacked washer/dryer. Model: 110 88752793 which is, I believe a 2003 manufacture. Dryer will not heat. I've checked both T-stats for continuity (when cold which is all I've got) and they seem fine. NO LINT anywhere. I blew what was there out and vacuumed the rest. All circuits hot. DO NOT SEE A THERMAL FUSE TO TEST ON THIS MODEL. So the temp selector knob is left? Seems unlikely? HELP!
Have thermistor Part 3404154 on desk. (Has many other numbers on its surface as well as red slashed lines.) Have repeatedly tested it -- produces 0 reading on ohm meter/continuity as it should.
April 18, 2009
3 Suggested Answers
  • 986 Answers
SOURCE: I have a Splendide 2100 washer/dryer. Washer
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Oct 16, 2009
  • 2382 Answers
SOURCE: Hi Its a
Hi, this is a very common problem. Usually the issue is with the water valve or the "mixing valve" where your hot and cold water fill hoses connect to the back of the unit is the valve. You will need your model number to get the right part though. You can go to to find the part number for your machine.
Posted on Dec 19, 2010
Dryer spins but no heat
Conventional dryers are usually accessed by removing the rear panel. I would think these would be the same. Unplug the dryer and remove wires from heating element. Test for continuity with an ohmmeter. If there is no reading, the heating element is bad. Disconnect wires from the hi temp thermostat and test with an ohmmeter and if no reading it is bad. Sears has these parts available.
Nov 07, 2013 | Kenmore Dryers
Kenmore 24
What is the model number of your unit?
Nov 17, 2012 | Kenmore 98702 Stacked Washer/Dryer
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
The dryer will not heat. I believe the heating element is broken. Can this be fixed? How much will it cost to be fixed?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Aug 24, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer doesn't heat.
you have to remove the panel between the washer and dryer to get to it it is the smaller fuse on the heater box-mike
Feb 07, 2010 | Kenmore Dryers
My kenmore dryer stopped heating.
yes the price of fixing it is less then a new unit most of the time.
you might need new heating element or cut-off switch only.
Jan 19, 2010 | Kenmore 94702 Front Load Stacked Washer /...
Water leak from washer
The element is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
130 people viewed this question
Sal De
 Brian Main
Brian Main
