Question about Hotpoint UY46 Style Line Stainless Steel Electric Double Oven
Hotpoint oven clock
Unfortunately I do not have my oven manual any longer. How do you set the oven clock?? its weird. Thanks!!
  • 9 more comments
  • Anonymous Nov 04, 2007
    Hey, thanks for the solution, it was easy but I too don't have a manual and needed to set my clock!!
    Doug
  • Anonymous Dec 28, 2007
    thanks a lot very helpful!
  • Anonymous Apr 28, 2008
    Perfect!  It worked!! I've been in this rental home for 10 months and could never figure it out.
  • TRT1968 Jan 31, 2009
    This fix worked a treat on a NEB Verona electric built-under oven as well! Thanks!
  • Anonymous Apr 03, 2009
    This solution works for Stove Ovens as well - oven now at correct time after having been at BST constantly for 3 years - Thanks
  • barryr1dog Apr 30, 2009
    don't know how to set the clock on a dol667s oven
  • Anonymous Mar 14, 2014
    my oven started to make the beap sounds and shows the the letter F3 in the clock screen
  • Anonymous Mar 24, 2014
    Model GWC605FWNG00 Silhouette oven. How to set clock.
  • Anonymous Mar 25, 2014
    manual foe clock and auto cooking
  • Anonymous Mar 30, 2014
    How do I set the clock
  • Anonymous Mar 31, 2014
    Hw to set **** on oven
1 make sure all oven controls are turned off 2 press & Hold in both the cook period & end time buttons together 3 with both buttons still held in press either the + or - buttons to set the correct time of day 4 Release all buttons simultaneously the time of day is now set.
Posted on Oct 01, 2007
  • NORMAN TAYLOR Jan 07, 2012
    Thanks for the info I just put in a second hand bd 35 and had to reset clock to get it to work. lights not working poss bulbs , need manual though ???
How to set clock on GE DOUBLE OVEN STOVE MODEL #JB860SJ1SS
To set the clock on the JB860SJ1SS, press and hold the 9 and 0 keypads simultaneously for 3 seconds (or a bit longer). Then type the current time using the keypad. Press Start to save the current time. This is shown on page 13 of the manual; see item 7 Clock.
Sears Parts Direct has the manual available here: https://www.searspartsdirect.com/partsdirect/user-manuals/JB860SJ1SS-GE-ELECTRIC%20RANGE-manual . The direct link to download the manual is currently https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1508037L.pdf .
I hope this helps.
Nov 05, 2017 | GE Ovens
Candy FPP609X oven not heating up
8888 usually means the clock needs setting as it has been disconnected from the mains.
Oct 07, 2017 | Candy Ovens
How can I get my cannon Cambridge oven to work it seems like the minute button has come undone
unfortunately the oven clock has to be set correctly or else will not work
Mar 07, 2015 | Ovens
How do I get the ovens working if the clock works, but they do not?
You'll have to make sure that the clock has been set for Manual cooking and not inadvertently set it on Auto. However if your breaker tripped because of a fault on your oven the internal switching of the timer may have been damaged as a result of the fault.
Nov 10, 2014 | Viking VEDO205 Electric Double Oven
Oven door will not open
The lock motor (latch) has gone bad. Unfortunately, the part has been discontinued and is no longer available for this model.
Apr 24, 2012 | Amana AOCS3040 Electric Single Oven
Just brought a bosch oven and there no life in the bottom oven
If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
Hope this helps.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
Neff B1442 Oven -- Defective timer and clock
Hi.
Is it flashing AUTO, If it is and you can'y reset it back to manual, then you have faulty timer.
Hope this helps
Nov 25, 2008 | Neff U1661 Double circotherm super...
ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Sep 30, 2008 | Zanussi ZHQ575 Electric Double Oven
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Hotpoint UY46 Style Line Stainless Steel Electric Double Oven Logo
5,015 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
