Question about Dell Computers & Internet
Cannot get 926 printer installed
I have had it working before not lately. I was going to print day before yesterday not able to. tried to run disk would only go so far then i uninstalled and tried to reinstall no results now when i try to uninstall i get error messages #buildtemplateeror message or #nomultipleinstance#
I have the frivers and utilities that came with the printer photo all in one printer 926 phone number is 765 832 1782
    Problem Solver:
  • 19 Answers
Is the printer installed on your computer or not
Posted on Apr 19, 2009
MY SCANER IS NOT WORKING
Try running Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download the proper drivers. If using Windows 7 32-bit use the Vista 32-bit and if using Windows 7 64-bit use the Vista 64-bit drivers. Install the drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block communications.
Links to the patch(drivers can be found at...
Dell 926 Photo All-In-One Printer owners thread (W7)
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Or
Try Simple OCR
Rick
May 08, 2011 | Dell 926 All-In-One InkJet Printer
All my printers cords are plugged in correctly but as i go to print it says that the printer isn't communicating with the computer, I've tried everything that they suggest and nothing seems to work.
uninstal all of the printer software if your down loading drivers from the web download and save to your desk top. disconnect from the web disable your anti virus software and firewall. then run the install from your desktop. follow the same steps if your using a disk anti virus and firewall disabled. alot of these software programs see all in one drivers as virus like activity and wont allow a complete install.
Sep 02, 2010 | Dell 926 All-In-One InkJet Printer
Ink cartridge problem?
Try to re-seat the ink cartridge.
  1. Press your printer's button to position the ink heads for replacement
  2. Then gently pull out the problematic ink cartridge.
  3. Turn the printer OFF to reset the printer's memory.
  4. After about 3 minutes, turn ON your printer and it should now ask for the missing ink cartridge.
  5. Now gently put on the problematic ink cartridge in place.
  6. Let the printer re-charge the inks and clean the ink heads afterward through the printer's maintenance program installed in your computer. (Go to "Printer's and Faxes, right click on your installed printer, then click "Printer's Preferences. Go to the "maintenance tab" and click on something like Print Head Cleaning.)
Just give it a try.
Jun 04, 2010 | Dell 926 All-In-One InkJet Printer
New computer/no disk
Go here for the drivers:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PRN_ALL_A926&os=WLH&osl=en&catid=&impid=
They have drivers for windows xp, vista and windows 7. Just download and install
Apr 15, 2010 | Dell 926 All-In-One InkJet Printer
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
Incorrect port detected 926
Try reinstalling the drivers for your printer. You should have a disk that came with the printer. If you don't then you will have to search the Dell website for the drivers. Once you have found them, reinstall them and see how that works out.
Let me know wether this helped or not.
Feb 11, 2009 | Dell 926 All-In-One InkJet Printer
Communication Error DELL 926 AIO Printer
Found on another forum. For 926 this worked great.
1. Go to Control Panel - Printers : Delete 926 printer
2. Go to Control Panel - Programs and Features : Uninstall All Dell 926 related software. There should be 3 programs. (When prompted to restart, respond to wait.
3. Rename Folder C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32x86 to W32X86OLD
4. Now restart your computer
5. Reinstall 926 Software.
This worked terrific for me.
Jan 16, 2009 | Dell A920 InkJet Printer
Dell photo 926 printer communication problem
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Oct 05, 2008 | Dell 926 All-In-One InkJet Printer
How to install hp 21 cartridge into dell 926 printer
Use only genuine cartridges with your printer. Printers these days have a built in sensor that can sense non compatible/generic/refilled cartridges and wont install them. It will only cause you more problems in the long run if you use a generic cartridges.
Best bet is to buy genuine inks..
Sep 28, 2008 | Dell 926 All-In-One InkJet Printer
Computers & Internet Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
