Question about Gigabyte GA-8KNXP Motherboard
Gigabyte GA-8KNXP wont goto POST
Hi, I've got an 8knxp (rev 1.0) based system, which was working fine up untill yesterday. Problem now is, when the box is powered on, nothing comes up on screen and no beeps from the box. I've tried the regular fault finds and diags, (stripping back to bare CPU, RAM and vid card), but no joy. Also, I know the CPU, RAM and vid card are fine coz I tried them all in another system and they all worked fine, so does the monitor. Oh, and yes, I did try resetting the CMOS as well by taking out the battery (no jumper for that on the 8knxp). Any ideas would be appreciated.
  • Choljah Sep 19, 2007
    There is nothing wrong with the power supply, as it powers up another system perfectly.
Asus is alot better than gigabyte i have repaired over 200 mothreboard this is the worst **** you can think off for starters you a server with raid drives then the board goes bios image is set for firmware for that board that should go back in their gigabyte warranty is so bad they do not fix what they sell and when they come back their still fucked so the new ones are good so forget gigabyte as a service company elitegroup these boards are the worst boards of them all they do not repair shit you want good product serverboards tyan,asus,intel,ami other companies who are following the path shit services msi ,biostar,soyo theys more [email protected] has been at the game since 1982 derek k certified component level support i decide what to put in systems garbage product will not rule the market i will burn you guys very way i can i have scraped 100motherboards so far i am also intel,amd msdn,technet sun apple registered so you are other resellers will know
Posted on Dec 06, 2007
  • 3 Answers
The Power Supply dude/dudette, Ive jst gone through the same thing and found Power supply was fried... Got it working fine now... gotta update Bios tho.
Posted on Sep 19, 2007
SOURCE:
Where is the Driver for a SataI HardDisk when installing Windows 7, which is attached to a Gigabyte 8KNXP Motherboard? The Gigabyte 8KNXP Driver Download site has a Driver but it's for Windows XP.
According to Gigabyte, you have a Silicon Image 3112/3152 SATA chip on that motherboard. Below is a link to the Silicon Image support page. Here, under the Product support pulldown you will choose either of the two numbers (3112/3152) and scroll down the list and you will find a driver for Windows 7 for 32 and 64 bit 3x12 chips (where the x is any number). They also say to use the newest BASE BIOS and there are tips to update the chip's BIOS. I've never tried this before, but hope you have good luck!
Support Library
Nov 08, 2015 | Gigabyte Computers & Internet
GA-8KNXP 4 X 1 GB Ram Bios shows 3.500 GB
This is because you are running 32 bit system. 32 bit system can only use up to 4GB RAM theoritically but some only 3.5 GB RAM.
Only 64 bit systems can use 4GB RAM and more.
Feb 02, 2010 | Gigabyte GA-8KNXP Motherboard
Fans work ram led lights etc. but no beep and monitor remains on standby.
ur motherboard have problem u much prepaire or change new one
Jan 17, 2010 | Gigabyte GA-8KNXP Motherboard
CANT BOOT WITHE HARD DISK SATA ON MATHREBOARD GA-8KNXP / GA-81875
The computer has to be programmed for SATA. Please provide us with the symptoms in detail and we can help you. We will also need the computer Name, the Model Number and verification of the numbers corresponding to your motherboard.
We thank you for considering our service.
My name is Constantin (Arzconst)
May 17, 2009 | Gigabyte GA-8KNXP Ultra Motherboard
Gigabyte motherboard GA-8KNxp will not power up
If you have just installed a new mother board, refer to your manual and double check your connections for pwr switch. If this is a machine you've had for a while and it just stopped powering up then your power supply is probably broken.
Feb 23, 2009 | Gigabyte GA-8KNXP Motherboard
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Jul 22, 2008 | Intel Motherboard
Cannot load windows
hi cpfish,plz do let me know what kind of error message do you get when you are doing the setup so i can get you the best solution.
raj..
May 12, 2008 | Gigabyte GA-8KNXP Motherboard
Gigabyte GA-8KNXP not going to POST
You can find leaky caps...
Anyways, those boards have very small inductors that look like caps and are used as pico fuses on most all peripherals and controller chips. Check that they are not blown and replace them with something from DIGIKEY or MOUSER
Also starting with the most simple, check that the power supply itself has not gone into SHOCK. unplug it from mains and TOGGLE the voltage selector switch, MAKE SURE it is back to 110 or whatever you need.
I know it sounds weird but I have resurrected MANY PC's that way.
Other then that it sounds like you are well on your way to finding the defective component on your own. just thought I would throw in the fiew things that have caught me off guard in the past.
May 01, 2008 | Gigabyte GA-8KNXP Motherboard
Memory DDR
have you checked the memory settings in the bios check the manual how to do this
Feb 20, 2008 | Gigabyte GA-8KNXP Motherboard
Gigabyte GA-8KNXP Motherboard Logo
276 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
