Question about Kenmore Elite 45986 Front Load Washer
Loud Knocking My Elite makes a loud knocking sound when in the spin cycle. I can rotate the drum by hand and the knock occurs twice per revolution. It does not knock in wash cycle when turning clockwise, only counter-clock wise. I took the back off and ran the spin cycle, noise apprears to be coming from inside the drum and very pronounced around the drum pulley area. I ran diagnostics and they were fine. Off course the warranty has run out, is this worth repairing?
  • Anonymous Mar 14, 2014
    the inside metal drum seems to have come off something and not spinning straight and knocking has it come off some kind of rubber runner ?
  • 209 Answers
This is a collapsed drum bearing, one of the most costly of the repairs apart from the timer and motor, not normally a job for the diy man unless has an engineering background, sorry, the cost of repair depends on the age and replacement cost of a machine, a bit like a car, would you buy an engine for a 20 year old car, if you have a machine thats expensive then the repair could be worth it? stop running it you will cause more damage both to the clothes and the machine sorry (ps i am a retired appliance engineer of 20 years service)
Posted on Sep 19, 2007
SOURCE:
Why is my washer making loud knocking sounds?
the bearings may need to be changed
Aug 18, 2014 | Washing Machines
Front loading washing machine makes loud knock on spin cycle
Move the empty drum by hands upp and down listen for noise, drumbaring my have been worne. Or is there some loose outside drum?
Feb 08, 2018 | Kenmore Washing Machines
My Elite H3 washer has been making a loud knocking sound during spin cycle for awhile now. Recently the clothes have been coming out wet. Today the drum stopped all rotation. I took off the back and the...
it sounds like the spider gear is bad,this is usually from using to much detergent,you can check the shocks but it sounds like the gear is gone.you'll know when it's the gear,it's very loud in the spin cycle,unfortunitly the gear is around 4 to 5 hundred dollars and then there's the labor bill,most likely better off replacing the washer.check out this video and you'll hear the sound i'm talking about....... YouTube - Kenmore front load bearing 18 months and kaput!
Mar 21, 2011 | Kenmore Elite 45986 Front Load Washer
I get a loud knocking sound on each revolution of the drum during the drying cycle (not caused by the load)
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 07, 2011 | Washing Machines
Hotpoint aquaries wf321 is making a loud clicking/knocking noise when its in the spin cycle, to me sounds like a poss bearing gone or maybe something is caught up?
From the front of the washer, spin the drum by hand, if it feels rough or is noisy or rumbling, then the drum bearings have failed.
It is possible that there is something caught between the inner and outer drum.
Nov 30, 2010 | Hotpoint Washing Machines
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
474 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
