Question about Radio Communications
NOONE CAN HEAR ME BUT I CAN HEAR OTHER PEOPLE
WHEN I GO TO TALK ON MY CB ITS TELLING ME I HAVE AN ANTENA PROBLEM I BOUGHT A NEW COAX CABLE AND I HAVE A 10 FOOT WHIP AND A SPRING
    Problem Solver:
  • 15 Answers
You need to check the connectors on the coaxial cable that plugs into the radio and antenna with a resistance tester from the pin in the center to the outer case there should be a resistance of infinity any reading on the meter says there is a short circuit in the cable and u will not transmit make over the connectors on both ends of cable make sure the center and outer wires do not touch
Posted on Apr 19, 2009
NOT RECEVING OR TRANSMITING
Can you see the s-mete if it has one moving up and down on any channel? Do you hear any audio at all? could be a couple of things. Bad mic switch or mic cable, bad antenna or coax, bad audio amp. To check the audio amp plug in a speaker to the PA jack, put the PA switch on PA then press the mic to talk. If it works the audio is fine the mic is good and the mic cable is good. Noiw plug the speaker into the speaker jack, do you hear anything? If not then your antenna or coax has a problem, fix or replace antenna or coax.
Jan 04, 2013 | Radio Communications
How to match a cobra 29 ltd classic to its antena
You will need an SWR meter to check your antenna. FIRST.
I would find help at a local cb shop.. They SHOULDN"T CHARGE to help you SET the swr. only if you need a part or something ..
I don't charge to SET SWR"s .. only if the cust needs a insulating washer or another antenna, or new coax, so-239 etc... I would be glad to help you.. let me know if we can -- CB Shop Temple, TX
Nov 26, 2011 | Cobra 29 LTD CB Radio
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
May 29, 2010 | Cobra 75 WX ST 40-Channels Handheld CB...
Tried to used CB without antena
If you were trying to transmit without the ant. then your assumption about the demise of your radio is correct.If you hooked it up using an inline fuse ,then just change the fuse. If you hooked up without a fuse, then no, you can not fix it. Please rate this answer.
Apr 09, 2009 | Cobra 29 LTD CB Radio
With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Mar 26, 2009 | Uniden Radio Communications
I can hear others but when i talk noone hears me
Try switching a different mic, sometimes the transmitting wire comes loose inside the connector. If you are handy enough, you can even unscrew those two tiny screws on the end of the mic cord and see if a wire is loose and if so, solder it back into place.
Oct 04, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Hearing loss
If your setup is able to rx and tx with no problems, sounds like his coax or antenna is bad. First, I'd try out his radio in your vehicle, since you know yours is working good. Just to see if it rx and tx good. If so, I would check his antenna and coax to see if they are good.
Dean
Rollin CBs
Sep 25, 2007 | Cherokee CBS2100 40-Channels Base CB Radio
Radio Communications Logo
88 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
