Question about Kenmore Sewing Machines
My machine isn't feedig the material through anymore!
  • 128 Answers
Sounds like your machine is out of time.
Posted on Apr 20, 2009
TacsewKM1243A only sews in reverse how can i make it go fowoad ?
1. Take the top off your machine.
2. Move the stitch length back and forth and watch the arm inside .
3. By doing this you will see where the arm is connected. The arm is probably loose or stuck by old grease. Look on the arm for loose screws. Tighten them.
4. If you see old grease that is hard and dirty you will need to clean it off. Use carburetor cleaner. Use old rags and a qtip and toothbrush. (Don't brush with it anymore)
5. Recheck to see if the mechanisms inside move by the arm.
6. Put some material on the sewing machine w/o a needle or bobbin inside. Turn the hand wheel and watch the material. You will have to move the arm to different areas to see differences in the material movement.
7. Once the material is moving you can put new oil on all moving parts that touch each other. (steel against steel)
Remember loose screws, old grease are probably the problems.
Mar 28, 2015 | Sewing Machines
How do I fix my Singer 15- 91
Make sure the machine is oiled properly and motor not burned
Apr 30, 2013 | Sewing Machines
Singer sewing machine 6233
have you checked your feed dogs are moving? have you dropped the feed dogs by accident? the feed dogs might need a drop of oil on the moving parts inside your machine.
Apr 23, 2013 | Singer Sewing Machines
The feeder plate isn't working. how do I fix?
here is a link for a free manual see if it has the information in it
about the feed dogs, some machine have a lever to adjust the
feeddogs and some don't
http://www.singerco.com/uploads/download/864_white-970,972,979-x-.pdf
Dec 02, 2012 | White Sewing 979
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
Something is wrong with bottom thread. It makes a mess of thread under the material when sewing. It seems to cut the bottom thread about every 5 inches and continue on.
First check that your needle isn't bent - it sounds like it may be dragging against the back of the hook. Dont 'pull' the material through - let the feed-dogs do that. Probably best to get it checked-out by a competent Bernina agent
Jul 24, 2011 | Bernina Activa 130
Hi iam not sure how explain my problem with my sewing machine.when i try to sew the strings does not comes stright. it gets messed up the top comes ok but the bottom of the layer comes out all strings...
If I'm understanding the problem right it sounds like you have no tension on the bobbin. Take it out and see if the thread has any resistance when you pull it out. If you hold it up by thel thread and let it dangle and it just drops to the floor the tension isn't right. Check and make sure it is threaded correctly and tighten the tension. Test it again and when you dangle it, it should drop a bit with resistance when you hold it by the thread.
Also check that the top tension isn't too tight, but in this case it is more likely that the bobbin is too loose. And check to see if the dogfeed (the teeth that comes through the plate opening under the needle) is up and moving the material through the presser foot. If the material isn't moving at all it will sort of stitch "in one place" which will give you a bunch of threads all knotted up underneath. If those underneath threads are loopy that is a sign the bobbin thread is too loose (tension too loose)
Apr 21, 2011 | Kenmore 15516 Mechanical Sewing Machine
My PE750D isnt picking up the bobbin thread and ripping the material, any ideas?
Hi,...either the needle is bent or damaged or the machine is not in time anymore. Try a new needle and see if that works. If it is the timing, it is time tosee a serviceperson.
Doug
Aug 05, 2010 | Sewing Machines
The machine will not pull the material through anymore.What can I do?
Is the feed dog lever up?
does the feed dog have lint in it?
Is the pressure foot set pressure set too weak?
Sep 23, 2009 | Singer Inspiration 4206
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
