I have a Gateway 3520 laptop. I formatted the hard drive and installed XP on the drive. After powering on the laptop. You see Windows XP logo and when the hard drive tries to boot I see a blue screen message. The blue screen message flashs to fast to read and the laptop reboots. I can start the laptop is safe mode only with out and problems. I installed a new laptop hard drive and I got the same problems as above. Could it be a bad motherboard?
  • 2,229 Answers
Do this:
Start the computer in safe mode.
If it starts OK, then click on Start and Run and then type in msconfig.
In the next window go to the startup tab (upper right of the window).
When the tab opens, at the lower right, click on disable all.
Now restart the computer normally.
If you had a bad motherboard, it would not start in safe mode.
One of the items that showed up in the startup tab is causing the problem. You can run msconfig when running normally and enable the things one by one until you find the one causing the problem.
Oh--BTW--after running msconfig, when you start Windows, you will get a message saying the the utility had been run. You have to click the little box at the lower left of the window, or it will throw you right back into the configuration.
Posted on Apr 18, 2009
How to format/install SATA 2TB hard drive (BARRACUDA) in Gateway GT5098E, Win XP Media Center Edition 2005?
Windows XP doesn't support SATA. You will need to use a program such as Nlite to integrate sata drivers into a new Windows XP disc. Once you have a disc with sata drivers just boot to the disc and follow the prompts to format the drive.
Jan 04, 2013 | Gateway "HITACHI DESKSTAR 0S02861 2TB...
I am unable to format the hard drive on my Gateway Laptop. I am trying to wipe the drive by formatting it but no luck so far I try to use the Disk Maintenance program in Windows XP but it doesn'
You can't format the active drive / partition within itself. It's like throwing away your clothes while you are wearing them in public. You just can't do it. Sorry, that's the only analogy that came to mind.
You format it with a boot disk like, an OS installation disc, USB drive with an OS installation, or a boot disc you found online (CD or USB).
If you have none of those, boot to command prompt by pressing F8 during boot. When you get there C:\ Type format c: Thats it. No going back, so make sure you saved and backed up your documents. You also need a way to install an OS, if you intend to do so.
Oct 05, 2012 | Computers & Internet
I formatted my hardrive and when i want to install Windows Xp it starts fine but then tells me that my hardrive is not installed,how can i fix this? "Setup did not find any Hard Disks Installed in...
Windows XP needs the SATA textmode drivers for it to recognise the SATA hard drive. This can be downloaded from this link:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2391
You will need the SATA AHCI driver
You must then burn the drivers to a CD or copy to a USB stick. When installing windows XP, you will be prompted "press F6" to load additional drivers, at this point the install will ask you to specify where these drivers can be found, if you direct it to the USB or CD Rom (USB is better to avoid disc swapping), it should find the drivers needed and then recognise your hard drive.
The above is a bit academic though, because this does not appear to support Windows XP according to the downloads options on the link
Jul 21, 2011 | Gateway T-6321 PC Notebook
Xp installation problem
Goto bios - disable sata operations and select hard drive type as normal, disable ahci, disable acpi
May 29, 2010 | Gateway T-6330U Notebook
Gateway M465-e laptop won't detect hard drive for XP install
The Gateway M465-e is only compatible the SATA hard disk drives. If the drive you are using is not a SATA drive, then it will not be able to work with your hard drive.
Dec 18, 2009 | Gateway Computers & Internet
Downloaded window 7 on my netbook and forgot to backup before installing i had xp
Sadly, there is no direct upgrade path for XP (pro or home) to Windows 7, only Vista. Windows 7 from XP requires a clean install.
Still, check the hard drive and see if Windows 7 moved the files to another location. It installs differently from XP or Vista and there may be a chance they are still somewhere on the drive. Use the search feature to look for a known file and see what happens.
Dec 06, 2009 | Gateway LT2021u Netbook
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
Gateway MX6927 Windows Xp won't boot
put your xp disk in the optical drive.Turn off computer. Turn computer back on as soon as you turn it on start tapping f 12 constantly.it should go the boot menu giving you a choice of booting from cd or hard drive choose boot from cd.Be sure you choose repair rather than new installation or you could loose all your information stored on the hard drive,I personally would try safe mode first you can get to safe mode by tapping f 6 when you first turn on your computer.
May 04, 2009 | Gateway MX6927 Notebook
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Hard drive not working properly
What is the original OS? If it's XP you can't install 98 over the top of it without formatting it to FAT32 first.
Nov 07, 2007 | Gateway Essential 500 PC Desktop
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
