Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Top Loader
My washer is six years old. No problems until now. I just completed a small load of "hand washed" clothes and found a silk robe had become lodged under the "wash plate". This washer does not have an agitator. I have the manual, but can not find how to remove the cap so I can remove the wash plate and untangle the robe. Does it take a special tool? Thanks.
  • Phyl John Sep 23, 2007
    Thank you for your help. There were a few extra steps on my model, but I was able to get to the problem thanks to your help. I could not have done it otherwise. I really appreciate your time.
  • Anonymous Apr 01, 2014
    removeing agitator from top loader
  • 5,911 Answers
The wash plate (or nunater) can be removed by following these instructions. It may seem like a lot, but the wash plate will not come out of the tub unless you follow the necessary steps: 1. UNPLUG THE WASHER. 2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. 3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal. 4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it. 5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Your clothing is probably tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Good luck to you and I hope this helps you. PS Don't forget to put the tub ring back in.
Posted on Sep 19, 2007
  • Jeff Rockwell
    Jeff Rockwell Sep 23, 2007
    Glad I could help you.
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Black specks on cloths after washing
I can't solve your problem, but I can say I have the same problem. I think grease is getting past the seals and getting into the washing basket with the cloths. I have a repair guy coming tonight. Hopefully he will confirm and fix. My machine is 9 years old and never a problem..till now.
Sep 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washing comes out with marks
Yank that dispenser off the top of the agitator and wash some clothes without it.
Apr 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Why does my washing machine leave lint on my clothes? does this type of washer have a lint catcher?
Most washers don't have lint traps, the dryers are expected to. In your type of top loader some simple traps would be located in the top cap of the agitator. They should be cleaned each load, but they only stop the bigger pieces.
Jul 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Leaves white clothes gray
Many of the machines are having a similar issue I am trying to find a resolution to fixing this, there are two issues. First Whirlpool has just recently identified a problem with premature bleach dispensing. Another dispensing problem I had is that fabric softener had to be diluted otherwise it would not wash out of the dispenser. And finally, the fabric softener dispenser would still hold a small amount of water after the wash cycle completed.Removing the top of some washers I have found that there is often a lot of stainless steel polish residue around the rim of the machine - which should have been cleaned away before the machine was shipped from Whirlpool. The gray, oily residue was not visible without removing the top of the washer. Knowing now what has caused the dark gray streaks on many peoples laundry.
Feb 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Load knocking sound
out of balance,or the clothes are not even spread and causes one side to be heavier
Jan 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
at this point i hate to do this but if yo want a free replacement you have to contact whirlpool. this was involved in a class action lawsuit and they are making the repairs for free. otherwise replacing the pump is simple and you can get them off ebay for really cheep. :)
Jun 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
722 people viewed this question
Dan Webster
Dan Webster
Sal De
