Question about Sharp SF 2020 Copier
Sharp copier 2027 roller toner light on - Sharp SF 2020 Copier
  • 1 more comment
  • ronkent Apr 19, 2009
    dot formation of upside down pyramid with curve line passing thur bottom dot. red illumination.
  • ronkent Apr 20, 2009
    yes I did add toner recently will try the solution this week. Thank you
  • Chris Coughlin
    Chris Coughlin May 11, 2010
    What is a roller toner light? Does it look like a star burst or a circle with to lines bent or a little man or dose it look like a log? Please be a little more discriptive
  • Sharp Expert
  • 1,326 Answers
Have you added toner resently? If so you will have to emptiy out the waste toner. The bottle is filled with toner and has set a flag in to a sensor.. I believe the waste toner bottle is in the front of the copier on the right side. It has been awhile scine I've worked on this model.... It may be behind a door on the right side of the copier toward the back of the copier... Be carefull when you empty out the bottle...... Use a plastic bag with No holes in it..... The toner will go every where if you are not carefull... Good Luck
Posted on Apr 20, 2009
How can i fix my aficio 2027 w/ loading toner error
Not loading toner is usually due to worn out dev gears in the PCU. Call your nearest Ricoh agent for a service call. A technician must come and fit new dev gears. Or the toner hopper is dirty and needs cleaning.
Jun 17, 2014 | Ricoh Aficio 2027 All-In-One Laser Printer
My machine model is SHARP AR 5520,the problem is that the machine is returning all the toner into the waste bin,all the toner will be sent into waste within an hour or two.this happened when i refilled the...
hello,
problem is your toner cartridge. inside of the toner cartridge have a toner roller it's didn't circling.or you are using duplicate toner powder.it's doesn't match with sharp ar 5520 developer. or your developer was expired.
first use original toner and try to make copies .i think your problem is solved.
Feb 05, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error code CH on sharp sf-2027
Hi olixrules
CH light blinking - The DV tank is not installed.
CH light steady - Door switch is not turned on (interlock switch is ON).
Source here.
Hope this gives you some idea, unfortunately I'm not sure how to resolve these error on this particular copier.
Scott
Feb 01, 2010 | Sharp AL-1642CS Copier
ROLLER ROTATING KNOB TURNS CONSTANTLY ON SHARP AL1631
Many copiers will do this if you have run out of toner.Copiers will turn over trying to add toner from the cartridge to the developer unit.
Nov 18, 2009 | Sharp AL 1631 Copier
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
Light copies
NEVER, EVER touch the "green roller" (drum). Are copies worse than before you cleaned it. I wouldn't be surprised
Mar 13, 2009 | Sharp AR-207 Copier
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
Sharp copier broken
your waste toner is full empty it there is a screw mechanism that feeds waste toner into the waste it makes a racket as it is blocked as the toner can go nowhere you may also be low on toner
Oct 11, 2007 | Sharp AR-207 Copier
110 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
