Question about External Drives
Dade mp3 player
Once i'v upgraded my mp3 player with wrong firmware,now when i want to upgrad my dade mp3 player i get an unknown flash error what can i do ? flash chip:k9k8g08u0a chip:2085 size:1G board ID : ACT16D_37
0 characters
1 Points
Upgrade ssd on Samsung NP900X3F
Samsung are the best brands depends on your budget and arability in your area.
Mar 10, 2014 | Samsung NP900X3F-K01US I5/1.8 4GB 128G SSD...
Format error
There is no problem with the pen drive, there is a problem with the music player.....
if you wanna play the songs on the computer then play it with VLC free player from the following link :
if you wanna play the song in your HI-FI music player or in your Car's music system , then convert them to ".mp3" format..... here is how you can convert to .mp3 format....
Goodluck ;-)
was my support helpfull ??rate me plz
Mar 09, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Sansa c150 2 GB MP3 Player
I'm not sure if you've read my Sansa recovery methods article, but I will repost it here in case there were any methods that you haven't tried. With this model, the recovery method uses the REC button instead of volume +. If all of these methods fail, I would simply connect the device to a PC that is running the same operating system as yours. Plugging it into a new machine causes a new reformatting which enables you to recover your device if these other methods fail:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Sep 25, 2008 | External Drives
Upgrade from Pentium 3 to Pentium 4
how in the world did you that exactly? usually this is not a simple item as the other chips are usually also upgraded, not to mention the Bios impact of that decision
Apr 27, 2008 | Dell Latitude CP (0001849d-38380-968-p06e)...
Usb flash pen drive
Often it is due to electrostatic charges on usb. Unplug all USBs.Unplug PC from power cable for 10/15/ minutes. plug back computer to power outlet and restart. Plug back usb.
If it still does not work , flash memory may be faulty, test it on a different computer.
Mar 17, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Nowadays, you'll have to scrap what you have and insert new 512M sticks, if you can find those in your design parameters...accordianman
Feb 17, 2008 | Memory Upgrades my14576 External Drive
Iomega zip 100 external
can you try reformatting that? it may readily upgrade itslef after reformatting it.
Jan 28, 2008 | Iomega ZIP 100 MB SCSI (10011) External...
Can't store anything lately
Hi, did you format the flash drive? If you are using windows, right click on the drive and select "Format...". You can repeat the operation a few times. If it's working, try to add your resume again. How old is the drive? Good luck!
Apr 25, 2007 | Memory Upgrades 1 GB USB 2.0 Micro...
Can't re-synchronize deleted files
your gonna have to reinstall all your stuff as I always tell peeps if you need to reformat or clean up your files and you got alot of data you should always have a copy or backup files on your puter. Sorry
Apr 11, 2006 | Apacer Memory APACER AUDIO STENO AV220 1GB...
External Drives Logo
43 people viewed this question
Top External Drives Experts
Brian Sullivan
Brian Sullivan
Are you an External Drive Expert? Answer questions, earn points and help others
