Question about Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, techmail@loudtechinc.com.
They hooked me up with parts and schematic for my Crate G212XL.
Posted on Dec 04, 2012
  • rusty_james3
    rusty_james3 Dec 04, 2012
    Novelist:
  • 157 Answers
Where can i buy the circuit board
Your best bet is to conact Crate customer service. Hereis their contact page-
http://www.crateamps.com/support/index.php
Nov 04, 2015 | Crate CA15 Cimarron Acoustic Guitar Amp,...
How do i replace the input jack on my crate gx140c combo guitar amp?
Is this an integrated socket that is soldered to a circuit board or does it have wires going to it?
Mar 03, 2013 | Music
Where is the serial number on a crate amplifier
Real basic owners manual is here:
http://www.crateamps.com/pdf/manuals/CA6110DG_OM.pdf
Look at the chassis, or pull a part number off the original speaker to match speaker and back cross reference to the amp versions that used it. The OM is at least good enough with the block diagram to allow it to be serviced easily enough.
Feb 21, 2012 | Crate CA6110DG Gunnison Acoustic Guitar...
Crate pa6fx powered mixer, powers on but when I hook speakers up to them, hear loud hissing and pops out of one of the speakers, nothing out of the other. I can hook up a mic and hear myself through the...
It is likely that there is a failure of one of the amps in the unit. It could be a cracked circuit board, bad solder, bad volume control, or a bad compnent in the power amp section for one side. HOWEVER something does NOT compute here as you can't connect more than one speaker to a 15 Watt Crate amp... Maybe you have two of these amps.
Dec 27, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a Crate v32 1X12 guitar amp, the volume cuts out and then begins to feed back. To make a very long story short the tubes are good (I KNOW the tubes are good!!!) it is not the cords pedals etc. any...
I don't know how you know the tubes are good... It is possible they are microphonic... try tapping them with a pencil (only need to worry about the smaller ones).
Beyond this look for cracked circuit board or bad solder... especially near the control pot leads. This is a common problem. Look for cracks near the booard mounting points.
Dec 23, 2010 | Crate Cfs3
I have a crate GFX 50 and the effects come in only after about 15 minutes of play.
This is a warm up issue and can probably best be found by using circuit cooler on suspected components.
Other possible problems may be a bad solder joint or cracked circuit board.
Candle the board with a bright light to look for cracks.
Bad solder joints take experience to spot, but pay particular attention where panel mounted volume controls solder to the circuit board. Looking for the little ring around the solder menicus takes a sharp eye and good lighting. Resolder any suspected bad joints.
Jul 29, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
It will not work what colud be wrong
its a crate. 60% of all crate amplifiers go back on defects. take the top screws out and slide out the chasis, look at the fuse and determine if its toast. if the fuse is good, get a new amp. if the fuse is bad replace it and you should be good. the circuit board will have the correct fuse to be used printed on the board.
yostamplifier.com
Dec 30, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a Crate PA-8 that hasn't been used in a long time. I destress and sing. Anyoo it has a power issue. Light is flashing on then goes off. I can't find a manual. Can anyone assist me please?
you have either a failing fuse or a failing power transformer. take out the screws on the top of the amp, leave the handle in tact and pull out the chasis. look at your fuse to see if it is in its holder correctly, and see if the fuse is burnt. the correct fuse values will be printed on the circuit board. if the fuse looks good then, it may be the power tranny going south.
May 08, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Apr 18, 2009 | Crate Music
Plugging line level into my crate TX15. all inputs sound distort
guitar amps are all set to a low Z resistance configuration. wich are made for guitar only. make sure you are using the right cables.
you need sheilded guitar cable not unshielded speaker cable in many cases these cables look exactly the same. look at your cable look for the words speaker or instrument. you need the instrument cable. if you still have that problem. then you may just not be satisfied with the quality of the amp it self.
Feb 26, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker Logo
905 people viewed this question
Top Crate Music Experts
rjivaro
Ben Armstrong
richie46
Are you a Crate Music Expert? Answer questions, earn points and help others
