Question about iRobot Scooba 380 Robotic Vacuum
I have a iRobot Scooba Vacuum Received an error message to check brush. I cannot get into the tank. Lever will not release.
  • ormemcginnis Apr 19, 2009
    My problem is with FixYa! I have pd for Premium Assistance and have an ID and password, however everytime I sign in and post the problem. I am asked to select a payment option. That's my major problem plus the fact I can't get the problem that I cannot open the tank with the lever and the error message is check the brush. Thanks Claudia
    Sniper:
  • 61 Answers
Press down on the silver tank saddle at the back of the robot. While putting pressure on the saddle, tap the release handle quickly, right at the edge. That should cause the tank to pop up.
~Fembot
Posted on May 14, 2009
IRobot Scooba 5800 "check tank" light
Why buy something used that is not in perfect operating condition? There may be other problems yet to be discovered.
Dec 31, 2013 | iRobot 5800 Scooba Vacuum
My scooba is not releasing water from the clean water tank
Sorry to read about your problem, I hope this helps you out.
if you have not cleaned out the unit very well you may have a clogged line, please look at the link
http://homesupport.irobot.com/app/answers/detail/a_id/654/p/31
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | iRobot 5800 Scooba Vacuum
NO water coming out of Scooba.  It's moving and rotating, but not emitting water.
Here's what worked for me.
Use a drinking straw to blow on the solution valve (next to the battery under the tank). If that doesn't work, try blowing a bit of canned air on the solution outlets on the bottom of the unit (in the trough in front of the brush).
Others have suggested using hot water to clean the solution and dirty tanks.
Jun 27, 2009 | iRobot 5800 Scooba Vacuum
Scooba problem
Does it put down clean water onto the floor? If so, rinse the four ports on the underside of the tank really thoroughly. You might have a clog; it's not difficult to dislodge it if you use enough warm water. Also make sure that the squeegees on the cleaning head cartridge (which holds the brush) are straight and in good condition.
If it doesn't put down water at all, try the tank rinse anyway, as it can help with that issue, too.
Jun 20, 2009 | iRobot 5800 Scooba Vacuum
Scooba says check tank and won't move.
Rinse the four ports on the underside of the tank with warm water, particularly the round opening that covers your Scooba's vacuum port and the curved one that matches the filter. Odds are, there's a clog in there and your Scooba knows it. Rinse the two oval ports as well, as thoroughly as you can.
Also, try priming the pump with water. The iRobot website shows how to do this under the Scooba troubleshooting section.
Then run the unit with water and vinegar (in place of the Clorox Cleaning Solution) if possible.
May 10, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
I cant open my scooba
If you haven't used the scooba before or if it has been a long time, the pump may need to be primed.  Go to irobot and do a search for how to do this.  I also had difficulty opening my scooba.  Press down with the palm of your hand on the back silver plate as you push down on the silver release handle.  This worked for me.
Apr 28, 2009 | iRobot 5800 Scooba Vacuum
IRobot 5800 Scooba Vacuum dirt not going into the fliter basket
You can try rinsing the tank very thoroughly with warm water. Be very sure that you rinse the four ports on the underside of the tank (one round, two oval, one curved like Scooba's filter) very thoroughly, because all the dirt and dirty water moves through those openings and can clog things up.
Fembot
Jan 02, 2009 | iRobot 5800 Scooba Vacuum
Scooba does not release water
I tried the straw on the solution valve. Worked last time, but no luck this time. I ended up using a can of compressed air on the solution outlets on the bottom of the unit (in the trough in front of the brush).
Jul 23, 2008 | iRobot 5800 Scooba Vacuum
Scooba doesn't put watter. Pump not working?
I calledthe company and they told me to forcefully flush warm water repeatedly through the valve that is just  above  the brush release button the the mechanical part  of the scooba.  It may take 20 or 30 flushes (I used a turkey baster, iRobot suggested a children's nasal syringe) and "Scooby" is  running great.
Jul 28, 2007 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
iRobot Scooba 380 Robotic Vacuum Logo
286 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
