Question about Compaq Presario CQ60-220US PC Laptop
I have a compaq presario cq60 215 dx. The rear lid (the back cover with the logo on it) needs to be replaced. Does anyone know of a website that shows this step by step??
  • 46 Answers
This is an online pdf that shows the removal procedures for the screen and bezel aswell as part numbers tthis should give you the bacic info you neeed to get started
h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Posted on Apr 28, 2009
I need instructions on how to replace the LCD cable for my Compaq
Too involved to cover in this forum however you can seach / download complete manuals for laptops that do give step by step instructions.
Apr 22, 2010 | Compaq Presario 700 470024-192 Notebook
There is recovery partition on my compaq presario CQ50 - 209wm and I'd like some help oh how I can use that to restore/reinstall my vista?
Normally during the early start sequence (when the laptop displays the Compaq logo), you will need to press F9, F10 or F11 repeatedly (model varies)
Some also require you to hold the key down before you press the power button, then release it after the laptop has finished displaying the Compaq logo.
Hope that helps.
If you are still lost, post back.
Peter
Mar 26, 2010 | HP Compaq Presario CQ50-103NR Notebook PC
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
Loooking for Parts for kodak dx 7440
bought a used non-workjing dx 7440 camera for cheap on ebay and just took mine apart and replaced the rear housing assembly. the solution to the parts problem was googling it and finding some ebay matches that were hard to find on ebay's site itself ...
Jan 27, 2009 | Kodak EasyShare DX7440 Digital Camera
Compaq presario 2200 screen stay dark
sounds like the inverter has gone, the only way to test this is to remove the laptop lid, remove the bezel (front plastic cover) please take care not to crack or splitt the plastics, then get an electical tester and test the inverter coil to make sure a current runs through it, if it doesn't its the coil, if it does you need a new inverter, the coil is located under the plastic sheath
good luck
Nov 14, 2008 | HP Compaq Presario 2200 Notebook
How do I replace a Compaq Presario V5000 laptop keyboard?
You need a flat bladded thin screw driver to prise off the long cover the runs along the top of the keyboard and just below the screen. Make sure you remove any screws at the back of the screen hinges, and along the top above the battery housing (you need a small posidrive screwdriver for this). You will find there is a screw on the underside of the laptop that holds the keyboard in place from underneath, plus two or three very small screws on the top at the screen end. When all the screws are removed you can lift the keyboard up from the screen end and pull (gently) away from the touch-pad end. Tilt it up and you will see the keyboard data ribbon, don't twist it or pull it as you will damage it.
hope this helps
Sep 23, 2008 | HP Compaq Presario V5000Z Notebook
Compaq Presario V4000 (v4118AP) right hinge broken
I had the same problem, they are very easy to fix, I did a search earliar and found some on the link below.
http://www.pchub.com/uph/laptop/291-29919-6327/Compaq-Presario-V4000-Series-Hinge.html
You do not need to dismantle to base, you have some star screws under the battary and one either side that loosens the small panel near the screen (where the power button is). The screen cover has screws under the plastic covers then just unclips, be gentle. after that it is self evident
Aug 06, 2008 | Compaq Presario V4000 Notebook
Blank screen on Compaq Presario X1000
Since u said that ur screen flashed and also u said that when u connected an external VGA nothing would display so from these two i can tell you that it is a hardware problem and that too with the VGA card/display card.
Thankyou
Feb 10, 2008 | Compaq Presario X1000 Notebook
HP Compaq Presario V2000 "Doesn't turn ON"
1) Unplug the laptop. 2) Press and hold down the standby switch under the lid in the upper left hand side of the laptop while pressing down the power key. You should have full power startup now. Let me know if it worked..
Jan 27, 2007 | HP Compaq Presario V2000 Notebook
Compaq presario 1200
there are plastic covers over the hinges, which may be part of the faceplate. being a compaq the hinge screws are most likely torx head screws. compaq used to make a special tool for removing the plastic covers on their laptops. the tool was a bar with a piece of fiberglas circuit board embedded in it. you insert the circuit board into the groove between the top and bottom covers and twist. this is, of course after removing all of the cover screws. some of the cover screws on the display may be hidden under rubber bumpers.
Jun 28, 2006 | Compaq Presario 1200XL104 Notebook
Compaq Presario CQ60-220US PC Laptop Logo
220 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
