Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wayne Dalton DoorMaster Model BDOR-2000/BIRW-2000
Light will not come on when I open or close the door...nor will it work from the wall remote.
Check the contact at the bottom of the socket and (with the unit unplugged) lift (or pull) it up to make contact with the bulb easier or tighten the bulb a bit more than normal.
Does the light ever come on?
Posted on Jul 28, 2009
Wayne Dalton DoorMaster Model BDOr 2000 door will close but then goes back up immediately. How do I adjust it. Nothing is blocking the closure?
The Wayne Dalton Doormaster design is a mess. I've had two of them in my house for 10 years, with numerous repeat problems.
What you are experiencing is a need to recalibrate the door, but the underlying cause is that a linear potentiometer becomes non-linear, and the calibration drifts. Once this starts happening, it will continue to be a problem until you buy a new potentiometer, or clean the one you have. If you are handy, it isn't too hard to do.
Two other Doormaster problems are when the DC electric motor carbon brushes wear sand clog up the commutator, causing the motor not to run. Another problem can be corrosion on the back of the circuit board that causes erratic operation, but can be fixed by scraping the corrosion off the board.
If anyone still is having any of these problems, post here and I'll do a detailed writeup on these fixes.
Terry
Jan 25, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have an old Wayne Dalton Doormaster Garage Door opener. It is definitely quirky, but when it stopped working this last week I called the Garage Door Guy to come and take a look at it. When he slid off...
Hi njitrrr,
Geez, that's a tough one! Other than getting a thick piece of Lexan and carving one out yourself....
There is a company, Ridout Plastics, that make some really tough plastic epoxies. I've used them and they are tough. As for gears, hmmm. I found their website and saw that they will fabricate a plastic part for individuals. Rare for a factory.
Here is the website that talks about fabricating parts: http://www.eplastics.com/Plastic/Plexiglass_Shape_Charges
Also, here's their site with the plastic adhesives: http://www.eplastics.com/Plastic/Adhesives?gclid=CJuT4pDOtKgCFUMUKgodNFTsDA
WeldOn #40 sounds likely. It might be worth a try to contact them about making a gear for you. Beats the alternative!
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Garden
I closed my garage door but when i came back home it was open. i just noticed it again after i left that the door opened by itself after i had closed it? The wall unit is Wayne Dalton model number...
Watch the door when it closes. If it is traveling too far and hits the floor the safety will cause it to reverse to the open position. This is a common cause. Also your door sensors may need adjusting. Make sure they are pointed at one another and the small light on each one is lit and not flickering.
Dec 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to have security with a lost wayne dalton garage door remote
Go to this site and follow the instructions.
http://www.1stdooropeners.com/299264coding.htm
May 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a wayne dalton garage door opener and the light stop working after and over ride or over use I let the motor rest and work again but the light stop working I replace the light bulb and nothing...
Try unplugging the unit for ten seconds.If that dont do anything youre have to call wayne dalton they should warranty the light socket replacement ,super easy to change out.
May 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door light...
Some of the newer light bulbs do not work well. Unplug the unit and look in the actual socket. There is a copper lead, pull it up a little and try it. If not then you can replace the sockets themselves. Although it may be the logic board too. Make sure and get a surge protector on this nit 900 joules or higher. Thanks BB
Apr 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opener activates itself--don't know how to correct it.
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Apr 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Wayne Dalton garage door will open with remote but not close. The only way it will close is to hold down the wall mounted garage door button. Then the light goes on and off while clicking. I have...
your infrared sensor is either misaligned, faulty, or you have a broken wire from your sensor to your door opener. (Flashing light indicates infrared light path is broken). both sensors should indicate green led. door wil not come down is safty feature to prevent door from closing when light path is broken.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door issue
stepper motor needs to be reprogram by a tech
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
2,197 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
