I have a Systemax Persuit 3200 and it stops right after turning on..... sometimes it has a static sound and shuts down. Most time it won't even boot up. When It does boot up it don't last long till it freezes or shuts down. Anyone Else have that problem or something similar?
My 91 automatic acura integra ls won't shirt
Check the transmission oil it may be the cause if not you will need to repair the gearbox with a specialized mechanic
Apr 05, 2013 | Cars & Trucks
PC won't stay on, doesn't make it past the boot up menu
the fan on the CPU working? Try a different power supply the one you have might be faulty
Nov 18, 2012 | HP Computers & Internet
Systemax Ascent HA3200 RTS won't boot - fans come on - no display
The motherboard seems OK as it is displaying signs of life. The Monitor should display something before booting up, which it is not.Please do the following. 1. Remove the RAM and reinsert the DIMMs into their sockets and boot up. 2. Disconnect the HDD data cable from the HDD and the motherboard and reconnect. Boot up. 3. Disconnect the monitor and reconnect. Boot up. At boot up press F2 and set the PC to default settings. Boot up. Later when you want to apply your settings, keep noting down what you did when. Just in case.
Jul 17, 2010 | Systemax Computers & Internet
Denon avr-3200
Check a few things first to narrow this down a bit. Disable the surround processing. If this clears up that channel, then the problem is in the processing area. If the static remains, vary the volume. Does the static change volume too? If so, then the problem is in the beginning stages of the pre-amp section and is likely a transistor or two breaking down. The parts for this would be in the $5 range. This would probably be considered a "major' repair becaue of the time required to hunt down the defective part.
Dan
Mar 28, 2010 | Denon AVR-3200 Receiver
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
Also,
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
Aug 29, 2017 | HP Pavilion dv6928us Notebook
Toshiba Satellite A55-S306 doesn't come out of hybernation
Turn the PC on, when it is booting up, keep hitting "F8" until windows boot options come up, choose "Safe Mode" and then once it boots into safe mode fully, go to the start menu and choose shut down. After it shuts down, turn it back on and it should go back into normal mode. From now on, don't use Hibernate, its buggy and has been since XP.
Feb 02, 2009 | Toshiba Satellite A55-S306 Notebook
Systemax laptop not shutting completely down
Try this ;
Buried deep inside Windows XP lurks a little-known program called shutdown that shuts down your system in a very fast � but orderly � way. Here's how to put an icon on your desktop that'll shut down your machine quickly:
1. Right-click any empty location on your desktop.
2. Click New, Shortcut.
The Create Shortcut Wizard appears.
3. In the Type the Location of the Item box, type shutdown -s -t 0.
It's important that you put spaces before each hyphen, that you have no spaces after each hyphen, and that you use a zero at the end.
4. Click Next. 5. In the Type a Name for This Shortcut box, use a name that will remind you that this button is for a very quick shut down.
6. Click Finish.
Jan 15, 2009 | Systemax AOL Optimized PC (100607) PC...
Stereo static
shut down all electrical sets around and check if the static goen the problem will be in electrical sets and you have to check it one by one.if it is not solved check your cables for any bad connector -open circuit- short circuit(try with a couple of new cables).-apply a contact cleaner in all sockets and move jack in and out in all sockets(with no power on)
Jun 12, 2008 | Audio Players & Recorders
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
