Question about Nokia 6300 Cellular Phone
No ringtone on nokia 6300
For some reason the ringtone on my phone has stopped working it will only vibrate with incoming calls. Has anybody else had this problem
  • Anonymous May 05, 2008
    i have nokia 6300 but its incoming sound is not working plz suggest me
  • eccles2 May 25, 2008
    the incoming ring tone trys to ring but is intermittent
  • 490 Answers
Hi envie & Anaagenius go to the main menu >setting >phone settings > restore phone settings  >code 12345 or dial *7370# then reinsrt sim & try (but before doing it take ur memory card out of the handset) ,if u still face any problem then dial *7780# but before doing it plz take back up of ur phone coz through it u may lose ur data of ur phone
Posted on Oct 14, 2007
Hi Envie, Envie,if u know any way to fix that problems me a favor,let me know ? Tnx. My phone also got that kind of sick..:-( I've been tne Nokia Care center....they said totally service repair charge RMB=1700.I was confused...Nokia care center repairing my phone or automatically and under the pressure try to sell products of Nokia...Lol China Nokia ....Do not buy any Nokia brand from China...all fake and just use repairing materials assemble re-new phones....
Posted on Oct 05, 2007
I think ur phones ringer tip has gone so just contact ur nokia care center.
Posted on Sep 28, 2007
Many thank to gizmo1. I've got my beloved 6300 back.
Posted on Apr 04, 2010
I had the same problem, and found that the phone's activated profile must have the "Alert For:" option selected.
To check this option:
- Go to Settings -> Profiles
- Select the currently activated profile
- Select the ‘Personalise’ option
- Scroll down to ‘Alert For:’ and change the value so it is selected (i.e. mark it so it has a tick)
- Select ‘Back’
- Scroll down to the bottom of the profile and select ‘Save’
- Select the ‘Activate’ option
Hope this helps.
Posted on Feb 09, 2010
The ringing tone just stopped - it won't ring with an incoming call. All settings are correct - and volume is set at the highest
try to assign a different ringtone (if it works its not a problem with the phone its with ringtone itself that you are currently using)
Aug 27, 2011 | Nokia 6300 Cellular Phone
Sir, nokia model 2626 Ring tone sound not coming when incoming calls comes speaker option is function all ringtone sounds comes only vibration please solve it thank u
The ringer is gone bad. Go to service center and just ask them to change the ringer. It will cost less than 100 rupees.
Make sure the phone profile is not in silent or in vibration only...
Apr 19, 2011 | Nokia 2626 Mobile Phone
My mobile (model: nokia 1650) restarts when I try to set the ringtone. My phone is now in silent mode and does not ring or vibrate for any incoming calls. Could you please provide a solution for the same....
you want to goto settings in your mobile phone and select restore factory setting, in that type the security code 12345 and press ok .then the problem will be solved
Dec 30, 2010 | Nokia 1650 Cell Phone
Vibration problem of nokia 6300 i want solutions
Does the vibration not work when a call comes or is it vibrating non stop? In either case you need to restart your phone and try calling to it to make sure it vibrates.
If it is not vibrating, then check phone ringing settings and make sure it is set to vibrate + ring.
Dec 31, 2009 | Nokia 6300 Cellular Phone
My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
I got this info off of page 60 from your manual.
Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
Set ringtone volume and incoming call alert options:
1. Press [Menu], then press "Settings".
Press "Sounds", then press "Volume".
2. Press "Ringtone".
3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
The volume settings available are:
• Silence all: All sounds are off.
• Vibrate : Phone will vibrate to alert you of incoming call or message.
• Off: Only the ringtone is muted.
• Ringtone mode: Low, Medium, High.
Tip • You can adjust the ringtone volume with the side keys.
Hope this helps. Let me know if I can help you with anything else.
Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
Phone only vibrates
Look under settings - tone settings and check what is under "incoming call alert", if it says 'off" the phone won't ring, set it on ringing instead.
Aug 02, 2009 | Nokia e65 Cellular Phone
Nokia 1100 incoming call is not ringtone but vibration is ok
Dear anusv99
You need to changed u r phone ringer, but somtimes it start by some claning, open ur mobile cover & clean the speaker area with the help of tooth brush gently,if it doesnt work change ringer
Please let me know ur comment
Feb 26, 2009 | Nokia 1100
No ringtone on Katana phone
Sure the phone is not in sient mode.Is loud speaker working. if not change N2150 ringer IC or get it changed with a technician.
Nov 19, 2008 | Nokia 1110i Cellular Phone
Nokia 6300 Cellular Phone Logo
690 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
