Question about Kirby Ultimate G Bagged Upright Vacuum
Cant seem to get the green light going on vacuum head,hook seems to be wrong way when its should be hooking the band off its doing the opposite
I have a kirby and when you put the vacuum head on the green light doesnt come on therefore its not working,the hook that loops the band on seems to be back to front . when it should be hooking the band on its unhooking the band and when it should be unhooking the band its hooking it on so the problem seems to be the hook is the wrong way around,is there a way of re-adjusting it so everything works the way it should ...please help?
  • Anonymous May 07, 2009
    the green light wont come one i dont know if i attached it wring or if im not doing it right please help!!!
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again (belt on).
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate.
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. New brushrolls are available here...  NEW KIRBY BRUSHROLLS
5)Look at the ends of the brushroll. The brushroll has three height settings...you should see notches AND  NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong.
6)Replace the baseplate by fitting the front clips into place and then push it down in back and secure it with the two rear swivel clips. Make sure it fits securely down over the bumper on all sides with no suction leakage.
7)Turn the belt lifter to where the RED arrows line up, making sure that the inner "hook" grabs the belt and stretches it up while you are turning it. Once you have the belt stretched up, put the power nozzle back onto the Kirby and lock it in place.
8)NOW...turn the belt lifter back to GREEN. If the little green light on the power nozzle lights up when you turn it on, CONGRATULATIONS!!! The brushroll is spinning!!
Posted on May 17, 2009
My Kirby is not picking up correctly, almost just seems to move fibers around.oves fibers, dirt around .Brush is engaged, green light is on. Any idea what's going on?
look for a blockage in the head elbow of the suction pipe or in the pipe itself
check foe air leaks that lessen the vacuum
Feb 15, 2016 | Kirby Vacuums
Kirby vacuum-The beater bar is turning, but the light is not on. Is something else wrong?
Check to make sure the magnet on the roller is on the side with the coil (this activates the light). You may have installed the roller with the wrong ends in the opposite sides.
Apr 11, 2014 | Kirby Vacuums
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
Won't **** the water back up, what is wrong?
Either the height adjustment isn't on the lowest setting or the belt isn't on properly so that the brushroll will spin. Here is a guide to tell you how to properly get the belt connected. It is written for the main power nozzle, but should give you the basics because the shampooer head works the same way as far as the belt hook-up is concerned...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
Mar 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Cant get rainbow shampooer to work
use the suction port for the vac hose
the water hose hooks to your kitchen faucet
Nov 11, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Belt
make sure the belt is in the middle before u put the head onto the vax front. turn the nozzle to red to hook the belt on . should be easy if the belt is int he middle space and up not down.. the the hook should hook onto the belt quite easily.. put the head onto the vax front and turn to green for go. the green light should be on if u put the belt on correctly .
Sep 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Can not put the head on so the belt will stay on
make sure the belt is position in the middle before u put the head on . hook the belt on by turning it to red. its easier when u put the height adjuster all the way up. slid the head straight onto the front. and lift the back so it goes over the ledge. and then pull the lock down to secure. amke sure the safetly switch is activated. then turn it to green. when u turn the kirby on if the green light is greena dn not off or dim or on and off. then u put the belt on correctly. if green light is not on . try again .. it comes with practise. once u get the hang of it .. its pretty easy
Aug 31, 2008 | Kirby Ultimate G Bagged Upright Vacuum
How do you apply attatchment for upholstery cleaner
If can only go on one way so it will lock. If it doesn't, then something is broken either the attachment or the hose end where it hooks to.
May 18, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Belt replacement
The belt handle should be turned so the red arrow is lined up. Then make sure the belt is hooked on the inner assembly handle. Reconnect the vaccum assembly to vaccum and turn handle to allow green arrow to align and the belt is hooked on motor rod anmd your ready to vacuum.
Jun 16, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
409 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
