Question about Mitsubishi VS-45607 45" Rear Projection Television
The tv acts like the cable has gone out even though it has not. on my mitshubishi rear projection 52 in
  • 2 more comments
  • fullthrot952 Apr 18, 2009
    coax cable
  • fullthrot952 Apr 19, 2009
    i do have the rca jacks but dont know how to hook them up to the cable. I did check it with another tv and it worked fine. what does it take to change the tv tuner? aprx cost of part?
    thanks for helping me, your advice worked perfectly. i am very happy with your service thank you ,fullthrottle1
  • jason May 11, 2010
    is the cable connected by the "coax cable" or the "A/V rca jacks" ?
  • 905 Answers
Do you have the yellow video and red and white audio rca cables ?
it will give you a better picture than the coax connection.
but the tv tuner may be going , so using the rca jacks would eliminate the tuner, but finding out which tuner is bad ( cable box if using one or the tv tuner)should be checked with another tv to see if it also happends to that tv , if it does not then the other tv tuner is bad and needs to be replaced
Posted on Apr 18, 2009
  • 1 more comment
  • jason Apr 19, 2009
    it depends on how they obtain thier parts , but can be $50 - $80 for the tuner and about $200 labor depending on the shop
    the "red & white audio cables will get connected to the output of the cable box to the input audio connections on the tv and on the same input the "yellow video in" on the tv will be connected to the "yellow video out" on the "cable box"( will not connect to the coax cable unless you buy a "RF to composite video converter" which will also have the audio L & R rca connections)
    also if it is only a " coax cable " connection and no cable box the conerter will not help to change channles , but you can use a "VCR" to convert the coax cable input to the video and audio rca output on the VCR
    your very welcome , and thanks for using fixya !
The timer light is continuosly blinking when i plugging in the tv (mitshubishi wd-5252) and won't reset?
Thats one of the famous capacitor issue most likely. Thats the V26 Chassis DLP and usually that symptom is caused by failed DM and Power Board capacitors. There is a repair kit that will work in alot of cases with that symptom. Its called The V26 Chassis DM / Power repair kit available at the following link with detailed instructions http://tvrepairworld.com/mitsubishi_repair_kits
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Closed Caption will not turn off even though the setting is off.
if using a cable or sat box check there as they also have CC
May 14, 2012 | RCA Televison & Video
52 inch GE big screen projector
Your TV is a RCA even though it says GE its made by Thompson/ Deflection Board Call UED 1-800-648-6657
Dec 31, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The screen has gone dim
If this has happened over time, then this is not so unusual for a 5 year old projection TV. If happened suddenly then there is a problem in the video circuit. The best thing would be have a technician look att he TV. Please take a few moments to rate my answer. Thanks...
Nov 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replaced lamp, no picture, turns to red light
please make sure to place Lamp Door/ Cover after installation of new Lamp in TV.
Jun 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitshubishi 52525
Yes, it is a cool down period. The fan will shut off after a few minutes.
Apr 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Says bulb has to be replace.
If your Tv is less than a year old you want to get ahold of Mithubisi NOW! There are two upgrades if you can call them that that adress the overheating and blocked airflow, And if the lamp needs replaced I'm sure you would rather have Mitshubishi pay for the 350.00 lamp than you
Feb 22, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red color gone on tv?
is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
Jan 29, 2008 | Zenith D52WLCD 52" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
171 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
