Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave oven
My microwave will alarm when not in use and it is as if someone is standing there hitting all the keys when no one is touching it. it also shows "F-3". do you know what this means and is there anything i can do?
  • GE Master
  • 9,173 Answers
The keypad is defective. GE calls it the "membrane switch". You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 22, 2007
SOURCE:
GE Spacemaker (LVM1750) Microwave Oven
If the source voltage, the fuse inside the unit are good someone has to follow the voltage in to see where it stops.
Dec 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Do the walls of a microwave oven need to be painted to reflect the waves?
You do not hve 2 attempt that, those surfaces are specialy designed to stand the high heat n humid environment n most paints wont stand that. It is either the paint wil burn or come off.
May 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave won't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
7sfy
May 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker model # jvm16505ho1 won't stay running
I have the same problem. It was/is a wiring issue behind the key pad. I unplugged the microwave and took the vent and key pad covers off - heed all warnings. Using leather gloves and needle-noze pliers, I removed the wire ties and reposition the wires. I also checked the plastic connectors for looseness. It's currently working, but for how long who knows. Mine is 3+ years old. I will never by another GE product.
I suggest you don't tackle yourself as the capacitor can hold thousands of volts even w/ the unit unplugged. Be careful.
Feb 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker oven keeps flashing "message - hit button for messa
If you have an "options" pad, press that and you should be able to get to the message sub-menu. If not, you may have gotten too much moisture in the key pad when you cleaned it and it will either need to be replaced or might possibly return to normal after drying out completely for a few days
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave with vent fan
hi possible magnetron problem but also check highvoltage capacitor and diode . the process of ellumination is the only way to help u .first disconnect connegtor to magnetron and switch oven on if noise goes away eureka repeat with other components
Mar 18, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
148 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
