Question about Harley Davidson Harley-davidson Motocyclette Hardwood Motorcycle
My bike is floaded how can i fix it - Harley Davidson Harley-davidson Motocyclette Hardwood Motorcycle
  • 39 Answers
Let it sit for awhile than try to start it if its still not starting install new spark plugs it should crank up
Posted on May 11, 2009
I have a 1998 kdx 200 the bike idles fine very crisp throttle When i rock the bike or move sideways or when rideing down a steep hill the bike boggs down it will stall if you let it I changed the float...
this might be a stupid answer, or question...is there a clip that goes around the float needle assemble on this carb...on yamaha when I worked on them they have a small clip that suppose to pull,push the fload needle valve...and which carb is this your talking about..
May 28, 2014 | 1998 kawasaki KDX 200
Why does my ccm 644 keep floading,had carbs off 2,3 times,i get it to stop,put the bike away for a week or so,go back to bike,try starting it and the carbs start flooding again,need help thankscarbs...
I think this may be another one of those faults due to the ethanol and other **** in modern fuels.
There is so much rubbish in petrol the stuff just wont keep also ther have been a lot of problems with the stuff rotting fuel lines this may be your problem, the float needle may be getting stuck by particles of fuel line.
May 06, 2014 | CCM Motorcycles
Car backfire smoke and spark came out tail pipe 2003 saturn ion
! Your injectors are floading the engine with too much gas. may be an injector stuck open, but not all of the fuel is burning in the engine and its running into the exhaust system, A hot catalytic converter ignites the excess fuel causing it to ignite and spark out your tail pipe. It can cause a huge fire. Dont drive it until its fixed.
Oct 21, 2013 | 2003 Saturn ION
My 2001 buick lesabre is pulling a random misfire code and spits and sputters and smells like the car is floading
find the fuel pressure regulator. you should see it mounted on the return line of the fuel rail under the plastic engine cover. it will have a small vacuum hose attached to it. Remove the hose and see if gas comes out of the regulator. If it does replace it immediately.
Apr 08, 2013 | 2001 Buick LeSabre
Intercooler line floaded with oil
CHECK YOUR OIL LEVEL IN ENGINE INCASE OVER FILLED THIS WILL SUCK IT INTO ENGINE, IF OK CHECK YOUR ENGINE BREATHER TO SEE IF BLOCKED CAN CAUSE BACK PRESSURE IN ENGINE AND START BLOWING OIL SEALS AND GASKETS, AND THE 1ST TO GO IS THE TURBO SEALS, YOU CAN REMOVE AIR INTAKE PIPE TO TURBO AND CHECK FINS INSIDE TURBO WITH YOUR FINGERS TO SEE IF ANY MOVEMENT IN SHAFT. PLEASE DO THIS WITH ENGINE TURNED OFF :)
Jan 24, 2013 | 2000 Audi A4
The fan does run and I saw the oil floading in the unit what's problem and what should I do ?
time to but a new unit
sounds like the compressor is cooked
compressor cost 100
install cost 150
sounds likke a no brainer 2 me
Aug 03, 2009 | Goldstar Heating & Cooling
Fisher Paykel F1 is blinking on both drawers - how do I resolve this without calling a service tech?
f1 is a fload code the bottom drawer has to come out and dry up the water make sure the power is off
Jul 13, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
I have a Fisher Paykel dishwasher that is beeping
you have to remove the bottom drawer ......
f1 fault is a fload fault
e-mail me and ill give you my cell number
cause im factory cert. for this company
Jun 23, 2009 | Dishwashers
VOLVO 850 T5 CAMBELT SNAPPED BENT VALVES, FIXED ALL THAT NEW BELT
Check the codes and see if any are stored. Make sure all the wiring to the sensors and engine ground wires are connected.
Bret
RepairPal.com
Nov 30, 2008 | 1985 Volvo 740
Harley Davidson Harley-davidson Motocyclette Hardwood Motorcycle Logo
99 people viewed this question
Top Harley Davidson Toys Experts
Tre Elkins
ray gallant
Mark McGinty
Mark McGinty
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
