Question about Dryers
No heat in dryer; tub turns; how to check fuse,thermostat,etc
No heat/ we took out the thermostat on the element housing--it has a rattling noise when shaken. I understand that is good. Should we next try another thermostat or how to check the element, which does not have any breaks? It is a 90 series dryer, model 11060922990. wandalmartin@yahoo.com
    Genius:
  • 1,122 Answers
If you don't have a meter and the element looks good i would change the thermal kit on the heater box,that being the thermal fuse and the high temp thermostat,you can get it at your local appliance parts store for around $10,let me know how you make out-mike
Posted on Apr 19, 2009
My dryer is no longer heating up and it does not time out, what parts would i need to fix the problems?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug
Whirlpool style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
Kenmore dryer bought in 2004 stops heating
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Thank You
Nov 01, 2008 | Kenmore 64852 Electric Dryer
I have a Whirlpool electric dryer model# LER5644AWO and I just replaced the thermostat/fuse (kit 279769)because I had the heating element checked in town and was told it was the thermostat/fuse.Dryer...
Check your breaker - a dryer will spin at 120 volts but needs the full 240 volts to dry. If that's not it, and it checks out to be your heating element or your thermostat fuse again, you may have some wiring problems in your house (possible power surges). Check your vent from the dryer to the outside of the house - if this is clogged, it may be shorting out your fuses. Hope this helps,..Good Luck...
Nov 16, 2009 | Dryers
Dryer will not heat on stackable kenmore washer
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Oct 15, 2009 | Dryers
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
My Kenmore electric dryer runs but no heat ....
Before I wish you luck i want you to review all of the possible reasons for your problem
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
May 29, 2009 | Kenmore 62602 Electric Dryer
Not heating
Hi, Check the thermostats and the fuse. Make sure the 4" vent to the outsideis cleaned. If it is plugged, it will cause elements and thermostats to go bad.
The thermostats and the fuse must have continuity. If they are open, replace them. All these parts are located in back on blower housing and element housing.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Drum Turns, but dryer won't heat up.
If the dryer does not heat at all then is either a problem with the heating elemet , or with the thermal fuse.
See the following suggestions from Repairclinic:
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Oct 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Heating Element rattling
I would not run the dryer and check the wires to the element and make sure there are no burned wires. I would also replace the heating element. It should not be loose in any way
Jul 27, 2007 | Maytag MDE2600 Electric Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
