Toshiba 40pw13p projector lamp problems
I recently purchased a Toshiba 40pw13p projection T.V. and am having problems with the crt's (i think thats what you would call them) With top casing and screen off the blue lights up fine, and the other two light up when you first switch on, but the green and red then flicker out. Can anyone give me advice on what is happening, and what I should expect to pay to repair? Please and thanks in advance.
  • Anonymous Nov 02, 2007
    I have a Toshiba 40pw13p projection T.V. and am having problems with the colours With the blue lights up fine, and the other two light up when you first switch on, but the green and red then flickerin and out. but if i left it on for 10 mins then turn it off for a bit , when i turn it back on its fine, just the red is slightly off. Can anyone give me advice on what is happening, and how to repair? Please
SOURCE:
SOURCE: Magnavox Projection DLP HDTV
I had the same problem...I took the back panel off the tv and took a small desk fan and mounted it so it would keep the bulb extra cool...IT WORKED! I left it like this for about a week. It shut off only twice after about 4 hours of on time. I then disconected the small white ceramic sensor on the back side of the light. (there is a plug conecting it, just follow the wire to it) It has been about 3 weeks now and I have not had the tv shut off yet. (disclaimer...could start fire from over heating? try at your own risk.) If it works for you buy a new sensor.
Posted on Apr 01, 2008
premtech
  • 934 Answers
SOURCE: Toshiba 40pw13p projector ic query
NO - - clearly not 140's.... You can upgrade Q751 & Q752 to 150's or 180's which merely have higher amp ratings and thus more reliable.
Also, make really sure that the "seller" you got these from isn't selling you chineese knock offs. They are common in this industry and they may not last ten minutes in your Tv. I suggest some place like ACME out of Florida http://www.acme-sales.net
where you will be assured of getting Sanyo original Ic's and not some chineese look-a-like.
Also, make sure to test the 3.3 ohm return and low ohm feed resistors in the convergence circuit when you replace the amps. You may find one or more resistors in the return changed in value or open so I would suggest buying a package of those also (10 in a pack).
Bill
Posted on Apr 05, 2008
  • 208 Answers
SOURCE: Panasonic 61" lamp bulb
Conact Chris at A-1 Factory Service at 303-722-3333 and he can quote the cost and ship an OEM lamp if you make a credit card payment over the phone. Tell him Les told you to call.
Posted on Jun 10, 2008
  • 4 Answers
SOURCE: Blue screen after 5 seconds took the back off and saw Green Lamp turn off
Just fixed mine with the same problem you all described:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on May 19, 2009
  • 1348 Answers
SOURCE: I have RCA p52754at, the red crt projection lamp
RCA sell them.
Posted on Jul 11, 2009
Buzz sound from Toshiba model 72HM195
Mine is doing the same thing. I think its the cooling fan. The bearing is probably gone.
Nov 22, 2012 | Toshiba 72HM195 72-Inch Diagonal...
I have purchased 3 new lamps. one lasted 900 hrs.
Your lamp is rated for 3000 hours. Is the fan working to cool the lamp? When you turn off the projector do you allow the fan to continue to run? If not the lamp is not cooling evenly and the lamp will fail. Th filters should be cleaned regularly and the vents be unobstructed.
May 14, 2010 | Toshiba TLPLMT70 Projector Lamp
It tells me that the lamp is not working
The lamp is probably burned out. They go after several years. You would most likely need to purchase and install another lamp(s)
Sep 21, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba 55 inch hdtv lamp
this is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
Sep 26, 2008 | Toshiba 55H70 55" Rear Projection...
Green light flashing & no picture on Toshiba 40pw13p
There is problem with the lamp. It might need to be replaced. The lamp unit is on the bottom-left side of your TV. Loosen thumb screw (by hand) to take the the lamp unit door. Using a screwdriver, loosen two screws of the lamp unit and carefully pull the lamp unit out.
Put a new lamp in reverse order.
Jun 28, 2008 | Televison & Video
Ive got toshiba 40PW13P rear projection tv and it has convergence problem where more then one colours apear on the picture.
Howdy,
Well, you didn't ask what you wanted but I think you should try 2 things. One; unplug TV's power cord for 5 minutes, reboot. Two go into the customers menu and try to adjust the convergence.
If these fail call a factory authorized service dealer. Good luck.
Jun 11, 2008 | Toshiba Televison & Video
Toshiba TDP-S8U Projector doesnt work
Hi j cwff
I would have said to take out the lamp and check for any visible damage , but if there is no response at all , you will most definitely be in for a Mainboard replacement that is going to cost a bit more than you might have expected.
I have however found that some people give the diagnosis of a faulty Projector totally wrong and it might be that the lamp is just blown - in which case the machine will switch on , but the lamp LED will flicker without any light being projected - then you can just get a new lamp for it.
Once you receive the Projector and checked it out for yourself , send me a request with any additional queries you might have and I'll happily assist you.
Thanks for using Fixya and good luck !
May 20, 2008 | Toshiba TDP-S8U Multimedia Projector
I have a Toshiba DLP 62CM9UA
hello everyone, I have been in this field for many years and if you have any problems about projector lamps or your projector ,pls just inform me and i will try my best to solve these problems. I am now still engaged in original projector lamp modules/ original bare lamp/ original lamp with housing/ replacement lamp/compatible bare lamp/main board/liquuid crystal chips/color wheel and other related accessories for the most popular projector brands... if u want to buy projector lamp ,welcome to contact with me. tks&best regards Grace MSN:[email protected] skype:myth_grace email:[email protected]
Dec 15, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba TP55F80 convergence problem?
check the convergence chips for bad solders or even the crt sockets, I would lean more on the ic's and surrounding area.
Apr 18, 2007 | Toshiba TP55F80/81 55" Rear Projection...
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Ekse
