Question about Dryers
Spring in bottom of dryer
THERE IS A SPRING IN THE BOTTOM OF THE DRYER.wHAT DOES IT ATTACH TO?
    Genius:
  • 1,122 Answers
If you found a spriing in the bottom of the dryer most likely it goes to the door,one spring on each side, what kind of dryer?lint filter on top or inside?mike
Posted on Apr 19, 2009
Dont know where spring goes as it was lying in bottom as belt had snapped
There should be a slot that the spring slides into in the bottom of the dryer
The belt rides against it giving it tension to hold it in this slot.
Sometimes they can be a nuisance,
Someone can hold the drum in position after getting the belt on so you can attach the front
(don't forget the door switch wires). Hope this helps.
Mar 09, 2011 | Dryers
How do i pull the bottom panel off?
instruction
  • Unplug the dryer from the electrical outlet to prevent accidental shock which could result in death.
  • Locate the two screws on the bottom base of the front of the dryer by tilting the dryer unit slightly up and unscrew the screws on both the right and left side of the dryer, and put the screws to the side. Some units will have spring clips on each the right and left side. Insert a putty knife and press back against the spring clip releasing it from its hole.
  • Pull the bottom panel off and set it to the side.
  • Dec 20, 2010 | Dryers
    Replace Belt
  • please comment on this on how it work and rate
  • Dec 20, 2010 | Crosley CDE6000 Electric Dryer
    I have a samsung dryer model DV209AEW/XAA. I "hand rolled" (dryer was off) the drum to get at a particular pair of pants from the dryer and I heard a loud bang. When I tried the dryer with...
    This photo is from a Samsung DV409AEW, but I assume they are quite likely the same. I also turned the drum (clockwise, which is the wrong way) and the same thing happened. The thud in my case was the spring that holds the tension pulley arm in place falling to the bottom of the dryer. If your situation is the same, spinning the drum caused the belt to come off of the idler pulley and the tension spring fell off. It seems to happen frequently based on web searches.
    Again, assuming the DV409Axx is the same, you can get at it from behind. There should be 3 screws (2 on the top and 1 on the bottom) of the plate that holds the vent pipe output assembly. That assembly can then be removed. There will be a vent pipe extension that comes out with the assembly.
    Once inside, see if the spring is off, and if so re-attach it per the photo below. It is counter-intuitive that the spring pulls the arm down, rather than to the left. Hopefully this will be your issue.
    Putting the pipe extension and outlet assembly back in can take a bit of fiddling... but if you lay on the floor, you can actually shine a flashlight in the crack to see what you're doing.
    Hope this helps!
    Nov 15, 2010 | Dryers
    Where does spring from pully go
    The spring will attach to the frame of the dryer.
    Hook your spring to the pulley and then try to attach it to the frame of the machine moving it to different locations on the frame, just remember it will have to stretch a little to attach so keep that in mind as you mentally try to hook it to the frame.
    Look very carefully at the bottom of the dryer frame, it will show a very slight wear mark, and that will show at which point to attach the other end of the spring.
    This is a FREE answer, Please Rate Me
    You can also purchase a owners manual for the dryer to assist you in this project...and future projects with this dryer
    Sep 26, 2010 | Amana Dryers
    Dryer does not heat, but does tumble clothes and blows air., what is wrong?
    Check the electric heating element. This is a long coil, looks like a long spring. That spring (coil) could be broken. If it is broken, you can just take it and twist the two halves together and put it back in. OR buy a new coil spring.. This is in the bottom of the dryer.
    Sep 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
    Simpson Maxidry Tumble dryer (Cloths dryer) How
    Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
    Jun 21, 2010 | Dryers
    I am haveing problem removing the front panel on my gas dryer?
    the panel comes off using a putty knife to release some spring clips 6568d2d.jpg
    Mar 07, 2009 | Kenmore 72802 Gas Dryer
    Broken Spring/Shock for my GLEQ642AS0 Fridigaire Dryer
    there are no "suspension shocks/springs" on a dryer, those are usually on your washer. here is hte par number for he washer spring 134144700(which is about 8 inches long and 3/4" in diameter made of heavy gauge steel) youll need (2) and heres the suspension shock absorber number 134564200 its a set of 2, there shold only be 2 on your machine.
    Dec 11, 2008 | Frigidaire Dryers
    Dryers Logo
    55 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
