Question about LG Heating & Cooling
115volt AC recharging
Can one recharge a Whirlpool model#ACD052YJO 115 volt window unit?
Is a kit available?
  • voided37 Apr 19, 2009
    Don't think there's a leak. Just isn't as cold anymore.
  • Ken Bledsoe May 11, 2010
    You can recharge if you need to got to find leak and repair. Then just weigh in the right amount of freon.
  • 306 Answers
Ok in that case it is dirty at the condenser side of the unit. To clean it is a little involved as you need to pull unit out of case and take some housing parts off. But if you take it apart and look at the condenser coils you will see a blockage of air flow across coils. Refrigerant doesn't wear out of just leak out once it is in system good till unit goes bad for good. When you clean the coils use a nozzle and try not to point at angle keep it square to surface. I have cleaned bunches of window units and you will not beleive the difference it makes it will work like new. Any ?'s just get back with me glad to help. ken
Posted on Apr 19, 2009
I have a window unit, model FAA067P7A2, and my dog chewed thru the power cord.
Buy a common 240 volt cord from a hardware store. Put cord ends(common hardware items) on to match existing.
May 27, 2014 | Frigidaire Heating & Cooling
How do you put freon in a whirlpool window unit
you will need a AC Tech to first 'repair' the leak and then to 'recharge' the system. Also, the Tech may have to 'weld in' service valves on the unit if it does not have them - which most window units do not have.
Note: unless you've had a 'leak' you'll never need to recharge the system. I would 'be sure' you needed to recharge the unit before having it recharged.
Sounds like you might really need to have a AC Tech look at the unit before you do anything.
Aug 04, 2011 | Whirlpool Electronic Window Air...
Does the Kenmore model 75180 run on 220 volt or 110 ??
Chuck, your particular model (which has been discontinued) had two different models with 115 volt (110 is no longer around) and 250 volt.The rating should be on the manufacturer's serial data plate. Also, you may be able to tell by the power cord that was furnished with the unit.
I have included a link to you Owners/Installation Manual, which will provide more information on how to determine what voltage rating your specific unit has.
http://www.managemylife.com/mmh/owner_manuals/23524/KENMORE-Air-Conditioner-Room-%2842%29-LR707330?brand_name_search=58075180700+KENMORE
Hope this helped you. Please let me know. Thanks.
May 18, 2011 | Kenmore 75180 Wall/Window Air Conditioner
I have replacedsurface unti terminal block with kit supplied by whirlpool part dealer. Though all other burners work on stovetop, the large burner still won't heat up. I alsp bought brand new element from...
Good morning,if you've replaced the burner and block and it still isn't heating,you definitely have a bad burner switch. On an electric stove you have two lines of 115 volts going through the switch to the burner. If one of the lines through the switch has burnt out,you may still get the burner on light. Hope that helps.
Jun 05, 2017 | Whirlpool RF302 Electric Kitchen Range
Keep burning power conversion plug on PC board I am running unit at 230 volts I have change transformer also
You should first start with converting the unit to run on 115 VAC if you can. We had a unit that went thru three ignitors, 2 selector boards, two main boards and a transformer in one summer in part because the electronics in that model are sensitive to spikes and spikes on a 230 circuit are worse than the same spikes would be wired for 115. Jandy was the source for that recommendation, not us.
Anyway, consider changing the line voltage and thoroughly inspect your main board to be certain it is not damaged. Assuming the main PCB is ok your best bet with a new part should be low voltage. Since we converted the unit we were working on it has been trouble-free.
John
Oct 26, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Recently my Whirlpool 115 volt dryer takes a long time to dry a
either u have a kinked venting or bad air flow,,, go outside it should be blowing well , do u have a long vent or goes up... if ur vent gets clogged or blocked can cause the problem u are having... if possible undo venting and blow it outside through pipe with leak blower and replace ducting hose from dryer to wall if built up with lint.... if not a venting problem then its possible it could be an operating thermostat inside the unit... hope this helps let me know
Apr 08, 2010 | Whirlpool WTW5800SW
Whirlpool wahing machine LSQ954PW2
Hello lmaichin
Welcome to Fixya
My name is Huum,
You said,
Machine stopped in middle of cycle and is in a froen state. Checked power 115 volts available to the machine. Suspect switch detecting lid opening is defective. Can not even find sensor switch. please HELP!
At this site you will find the diagram you need. Lid Switch is # 11
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Heating & Cooling Logo
85 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
