Question about Brother IntelliFAX 4100 Laser Fax
4100 brother fax
I fixed the date now my faxes are not auto fed through the machine
  • 163 Answers
Please check the settings again you have OFF the auto feeding fax programe
Posted on Sep 22, 2007
SOURCE:
When I send out a fax using a Brother Intellifax 4100 a black vertical line appears on document on the receiving end
this is a very common problem. You have to clean the scanner lamp glass. There must be some dust or correction fluid if you have ever used which has stuck on the glass of the scanner lamp which prevents the light from falling onto the originals. Lift the control panel, you will find the scanner lamp where theoriginals are normally fed, clean with a soft cloth and alcohol.
Jun 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Keeps time incorrectly
that's unfortunate, but there's no fix for that.
May 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Cannot receive faxes or copy, but can send out
make sure you auto recieve light is on.
check your lights the one for FAX only has to be on only.
not TEL or FAX_TAD
good luck>
Mar 21, 2009 | Brother IntelliFAX 4100 Laser Fax
Time date stamp on fax machine
The time it was sent, if they have the time set correctly on the sending fax machine
Mar 04, 2009 | Brother IntelliFAX 4100 Laser Fax
NEED THE MACHINE TO ANSWER WHEN THE PHONE SENDS THE SIGNAL.
After making my post, I went to the official Brothers website for the 4100 FAQs and "Operating Instructions." Here's what I found. Set your 4100 set to the "Fax/Tel" mode. Press "Menu", then the number 2 (Fax), then number 1(Set-up Receive), then number 1 again (Ring Delay). Use right arrow key to increase. Once increased, press the "Set" key. You'll see the message "Accepted." Now press the "Stop" key to exit "Menu." This will now give you up to 4 rings before the fax auto answers. Inorder to send a signal by phone to remote start the fax just follow the instructions I copied directly from Brothers instructions for the 4100: If you answer the call on an extension phone (this is any phone plug into a phone jack on the same line) and hear a beep every 3 seconds (automatic fax) or just silence (manual fax), press *51(remote activation code) on the telephone keypad, wait to hear the Brother machine turn on (chirping sounds) and then hang up. I don't have anyone that can send me a fax right now to test it out. I'll have to try it in the morning. Hope this works for you.
THEOH
Feb 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Cant receive faxes
Set your fax machine for AUTO RECEIVE. Unplug power cord and plug back in.
Sep 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Intellifax 4100
First the link to the manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100e_EN_250.PDF
The date and time are set up under general set up. Under that menu there is also TONE/PULSE dial mode setting if you have accidently changed this to pulse it will cause issue. Change it to tone if you have and this will resolve the problem. Pulse is the old style phone system.
Mar 05, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
27 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
