Question about Marshall Music
Seems to be a noisy fan on mb4210 combo
Hi there. i have a newish marshall mb4210 bass combo [ripper] but there's a whirring noise after about 2 mins and then that sound continues. it doesn't get any worse but it's annoying. i was expecting 'near silence' but maybe that's my misjudgement. could be the cooling fan? the whirring is on both channels so i don't think it's to do with the valve in the pre-amp section on classic channel. cannot hear whirring when playing; not terribly loud but when not playing i can hear it from one room away. front of head section of combo does also seem quite warm to the touch so maybe fan not cooling properly. suggestions? thank you very much, james
  • Marshall Master
  • 5,603 Answers
The fan is thermally controlled by a temperature sensor. There is NO interference you can fix with shielding. The noise is acoustic and you could try sound deadening. DO NOT block the airflow. This amp is designed to generate a lot of noise so things like fan noise is so far below the listening level the designers don't worry about it. With a 450 watt amp it takes a lot of airflow. The fan is likely throttled and will speed up as heat increases.
Posted on Oct 31, 2011
    Scholar:
  • 109 Answers
Could very well be the fan. The motors can cause interference. There may be a solution to get rid of the noise. Some copper shielding tape may help. You could rule out it being a microphonic preamp tube by turning the amp on as normal and tapping the tubes with something non-conductive. If you hear the tapping noise coming thru the speakers while doing this to a particular tube, replace it. With power tubes, the tops of them turn white on the top when they become microphonic, along with plenty background noise.
Posted on Jun 19, 2009
What is the modern replacement speaker for Marshall 27115 bass combo
You would be Seamus?
Eminence are not a high-priced speaker. You could replace it with one of the bass guitar speakers here, like the large magnet CB15
http://www.usspeaker.com/15.htm
Sep 26, 2016 | Bass Music
I have a marshall mb150 and sometimes it used to stop emitting sounds for a while but now in the sounds gets deemer and louder every now and then
A common issue with Marshall Amps are generally speaking a low resistor value cracked leg inside the power module, just open up the amp and with the amp unplugged from mains check by a little finger movement the big 2/3W resistors and possibly you will find that one or other will have a broken leg, also cold solder joints do this kind of issue, hope this helps...
Oct 09, 2013 | Marshall Amplifiers Marshall MB150 150W...
Fan will only start when you blow into it, and when it does start, it's noisy. Where do I get a Marshall replacement fan off the newer Marshall amps? These fans are said to be better than the ones...
Bearings have gone in it... The fans are standard part. Take number off the label and search for the same unit. Note if it has two or three wires. If it has only two wires, replace with one of same voltage and current or wattage rating and of course that fits size-wise. Three wire ones have a sensor and you are best to replace with exact unit.
Sep 19, 2011 | Marshall Mg50dfx 50-Watt Combo Guitar...
My Marshall MG 50 DFX has a noisy fan. Can I take it apart and give a shot of oil?
Bo, the fans cannot be lubricated. If the noise is from bearings, replacement is the only option.
Dec 05, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Can i fix one ampli marshall mg100 i had used my bass, and now my marshall have a very estrange noise
Well i know ive destroyed a guitar amp with a bass guitar before :-p this is why they make bass amps and guitar amps instead of just amps
Sep 25, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
My marshall mghdfx head fan makes noise when you first turn it on. what is this?
Some cooling fans are "throttled" depending on the sensed temp... these CAN be noisy upon initial startup.
It can also be bearings going out... best plan is to watch it and see if it gets worse.
Changing a fan is fairly easy. You have to observe the polarity of the connections. Replace with identical unit.
May 09, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall MG100DFX noisy
Before you bring this into a shop, try spraying out all of the controls. Use an electronics switch cleaner that contains a lubricant. Spray into the control and work the control back and forth a number of times to loosen up any dirt inside. Then spray it again.
Let me know if that resolves the problem.
Thanks,
Dan
Feb 14, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Music Logo
254 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
