Question about Cobra 22 CHANNEL 2-WAY RADIOS
Cobra PR4750WX - how do I adjust squelch?
I've had these radios for a couple years and in some areas the squelch just screeches horribly. Since it does not use a manual knob for adjustment, I don't know ho to adjust it's sensitivity. Any suggestions?
Thanks!
  • 50 Answers
You are right there is no adjustment. You can however turn the squelch off and this maybe what is happening to you.
To turn the squelch off you press and hold the button that is just below the push-to-talk button for at least 5 seconds.
To turn the squelch back on, you either press (less than 5 sec.) and the same button or change channels.
When talking with a specific party or group, you should use the tone coded squelch (CTCSS) and that will mitigate the noise if you are not already doing that.
Posted on May 28, 2009
    Problem Solver:
  • 6 Answers
The CTCSS and DCS when activated will do nothing for the squelch if it is turned on, you will still hear the squelch as I just tried it, I am having issues however with one radio not always ringing thru when the call button is pressed from another radio, the other two radio receive the call but this one is just silent.
Posted on Nov 15, 2012
No squelch/sound
turn squelch all the way to left and leave it there RF gain should be all the way to the right.Radio should be in CB not Pa mode
Mar 26, 2014 | Cobra 29 LTD CB Radio
Squelch won't turn off, won't go into power save mode
Power-save mode means the radio is being turned on and off repeatedly, to save power. The radio turns on, & if it hears any signals (i.e., if squelch circuit determines a station is being received), it turns on the speaker; else it turns off again to save power. So, squelch and power-save modes work hand-in-hand, and your problem is squelch circuit is either set too low, or a station is being received by the receiver. Download/look at the owner's manual and adjust the squelch circuit for a higher setting, and it should go into power-save mode again.
Good luck.
Nov 10, 2013 | Cobra LI 7020 WX-EVP Two Way Radio
How to tune squelch
you need a signal generator that costs more the radio you want turn the squelch up on.If its a one time deal its not worth it.If you intend on repairing radios then you will have a headstart. you need a service manual.the manual will tell you which vr to adjust.
Oct 07, 2013 | Cobra 29 LTD CB Radio
Low adio out put
Hi Peter,
Steps to try:
1: adjust volume up
2: Check batteries are fully charged
3: adjust squelch level
If all fails, join yahoo group specific to Cobra HH38WX and they'll give you the lowdown on this unit and you can freeely dowload user manual as well as other great stuff.
Hope this helps.
Chhers.
Peter
Feb 21, 2013 | Cobra HH 38 WX 40-Channels Handheld CB...
Cobra 75 wx st
Hi and welcome to FixYa,
Initially, pls a couple of ideas you may want to consider/explore or try/check:
  • PA/CB switch must be to CB;
  • RF Gain max clockwise;
  • Squelch counter clockwise;
  • Volume to your desired level;
  • Mute (off);
  • external speaker/speaker connection;
  • audio amp, verify if there is TX modulation;
  • antenna, antenna cable. SWR should be low.
Good luck and Thank you for using FixYa. Happy New Year.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate this at all. Cheers.
Jan 01, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
No Auto Squelch on Cobra PR4700WX
Yes sir, when u will open the set u can find two potentiometers , one is for tranmitter another for receiver . Try adjusting the same ( second radio should be transmitting ) do not switch one radio without antennae it may burn ..
Regards
raj/
Dec 24, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Squelch doesnt work
Open the component / speaker side cover on the radio, adjust VR3, this is the alignment control for the squelch. Set your squelch control knob on the front of the radio to about 10 o'clock and slowly adjust VR3 until the signal from the speaker is mute.
When you turn the squelch back to the 0 position, you should have signal with no squelch as in normal operation.
Thanks!
Dodgem
http://dodgem250.angelfire.com
Apr 06, 2008 | Cobra 29 LTD CB Radio
Horrible Noise
It may be a cold solder joint on one of the stand up boards. Check all your connections and solder any bad joints.
Ed
NC Electronic
Mills, Wyoming
Jan 02, 2008 | Midland 1001Z 40-Channels Base CB Radio
Cobra 22 CHANNEL 2-WAY RADIOS Logo
742 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
