Question about GPS
It never lets me take the freeway!
The only problem is that it always makes me take streets never the freeway even when using the freeway is the shortest and fastest way. If I am on the freeway it makes me get off..how can i fix this?
  • 88 Answers
You have the "avoid freeways & major roads" option selected. this is in setup which is completely different from the shortest route option.
Posted on Apr 18, 2009
I ask a question on what is the drive cycle to reset obd for toyota2005 rav4
Step One: How to Prepare Your Vehicle
  • Have the fuel tank between 30 and 70 percent full. Some systems, especially the EVAP system, need to have a specific level of fuel in order for the tests to be trusted. If the fuel tank is near empty or completely full, many of the basic tests will not run at all.
  • The vehicle must also have a good alternator and a strong battery. If you have to occasionally jump-start your vehicle, all of the memory from the powertrain control module (PCM) is erased, which includes the data that accurately tracks the results from various stages of the Drive Cycle. Also, if the battery is weak or undercharged, some of the most important tests will never run.
  • The vehicle must sit overnight, or for at least eight hours, in an environment that is less than 90° F. The engine temperature needs to match the air temperature in order to establish an accurate baseline for the testing. If the outside temperature is over 90° F, the fuel is too volatile and the EVAP system won't even try to run its tests, though some of the other emissions systems may run their tests.
  • The keys must be out of the ignition and all of the doors must be closed while the vehicle sits over night because many of the onboard computers "boot up" when the keys are in the ignition. Also, many of the onboard computers still run until all of the doors are closed after the vehicle is shut off and the keys are removed.
Step Two: The Cold Start
  • Start the vehicle and let it idle for two to three minutes in Park or Neutral. While it is idling, turn on the head lights, heater/defroster, and rear defroster for a three to five minute warm-up phase. Let the idle speed settle down to near the normal speed.
  • Next, put the vehicle in gear and drive through city streets at about 25 mph. Go up to about 35 to 40 mph a few times before slowing down to stop. Don't roll through the stop; be sure the car is really stopped, just like you learned in driving school. Accelerate from each stop in a normal fashion-not overly conservative, but not like you are competing in a drag race either.
Step Three: A Short Freeway Trip
  • After the vehicle has been cold started and driven for a few miles on city streets, the next step is to take it on a short freeway trip.
  • Enter the freeway on-ramp and allow enough room with respect to other vehicles so that you can do a 1/2 to 3/4 throttle acceleration up to freeway speed.
  • When you have accelerated up to around 60 mph and have safely merged into the flow of traffic, stay in the slow lane and maintain a steady speed of 55 to 60 mph for a minimum of five miles. Please use the cruise control to help you maintain speed.
  • Find a nice, long off ramp to exit from the freeway. As you exit, take your foot off of the accelerator and let the vehicle coast down until it stops under its own power as you complete your exit from the freeway. Do not use the foot brake and do not shift gears until the very end of this "coast down" phase.
  • Step Four: More City Driving
    • After you have completed the freeway trip, drive through the city streets for a repeat of the second part of Step Two.
    • Go up to about 35 to 40 mph a few times and then maintain a city speed of 25 mph before slowing down to stop. Again, don't roll through the stop and make sure to accelerate normally.
    • Pull in to a parking place and let the engine idle for one to two minutes and then shut it off.
    Step Five: Have your Readiness Monitors Checked and Verified
    • Drive your vehicle to your regular shop and have them re-check your readiness monitors, present codes, and pending codes. They should do this as a courtesy and for free.
    • If all of your monitors are "ready" and there are no present or pending codes, then your vehicle has been properly repaired and is ready for an emissions inspection and for normal driving.
Feb 21, 2017 | Cars & Trucks
How to do the drive cycle of a 1996 Nissan pathfinder
How to Perform a Basic Drive Cycle
Step Five: Wave your Readiness Monitors Checked and Verified
  • If your monitors are not ready, please click here for more information.
May 26, 2016 | Nissan Cars & Trucks
How to do the drive cycle on a 1996 nissan pathfinder
95 volkswagen cabrio clutch problems?
Sounds like your clutch may need to be replaced
Jan 07, 2013 | 1995 Volkswagen Cabrio
Taking on the city streets vs freeway
Poor ride over bumps is generally caused by worn or leaking shocks or strut cartridges...Most loose some ability to perform correctly in two or three years. Generally the fronts wear a bit faster than do the rears because they bear the weight of the engine and transmission, but you should have the rears checked as well. Buy the best ones you can afford but don't go overboard or you can end up with ones that are more durable than the OEM units but too harsh for most people's comfort. Except for "exotic" units such as Koni, price generally indicates quality...cheaper ones don't have the capacity to perform well, so a good mid range price will generally be the best choice.
You thought of this already...Why didn't you do it?.
May 28, 2009 | 2004 Chrysler Pacifica
We just used our Garmin nuvi 260w for a trip. From Az to CA it was telling us to exit off every off ramp. It was trying to get us to california using side streets. Is there something we can do so it will...
Press the wrench/tools symbol at the main menu. The select "SYSTEM", make sure you have the "Automobile" mode selected.  Any other will try to take you on every non-freeway route it can.
RustyP
Mar 25, 2009 | Garmin nuvi 260W GPS Receiver
1998 Bonnevelle bogging out
I re-set the computer an it runs great.
Jan 27, 2009 | 1998 Pontiac Bonneville
Speed problem
You have a carb problem. Check your piston vacume in your carbs.I had the same problem,and it was the piston vacume that had a hole in both piston.Good luck tom :D
Nov 20, 2008 | 1983 Honda GL 1100 Innerstate Gold Wing
My Garvin does'nt line freeways. It always uses surface streets
You are the only consumer product help site that charges a fee to learn how to use your product. Rest assured I will tell everyone I come in contact with and post on line with every site that applies what a crummy way you run your customer service.
Nov 06, 2008 | GPS
GPS Logo
89 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
