Question about Tascam CD-D1X4 Professional 1x4 16X Compact Disc Duplicator (043774017010) Burner
Repair CD drives and/or Clean the CD drives
There seems to be label tape (from Brothers label tape machine) stuck in some of the drives. How to clean the drives? How do I know when the drives should be replaced? The machine is 5+ years old.
    Sergeant:
    Champion:
  • 293 Answers
Try this Look at this image >> http://an.hitchcock.org/repairfaq/REPAIR/whole/cd532s.gif For more Info on repair >>> http://www.repairfaq.org Hope this helps
Posted on Sep 19, 2007
Videotape dubbing deck dead
1. Check to see if a tape is jammed inside (see 284 Extract a Jammed Videotape).
2. Try changing the video input and/or output source. Many VCRs have two ways to receive and send a video signal (coaxial and video direct). If that works, try changing the cable for the other method to see whether you need a new cable.
3. Clean tape heads (see How to Clean VCR Heads).
4. Open VCR and inspect any belts that are accessible (see 284 Extract a Jammed Videotape). A drive belt may be broken or loose.
If tapes are getting stuck / enmeshed inside the machine, itis 90% probability) a mechanical problem. Change the Belts, clean all rollers, idlers, and braking pads.
I would suggest that you also replace the Capstan Pinch Roller.
Goodluck..
Feb 17, 2008 | Rio Go Video DDV9556 Dual Deck VCR
Tip
How to Clean a Travan 40
<p>Travan 40 tape drive, manufactured by the leading data storage and backup device manufacturer Quantum, uses the tape storage business to 40 gigabytes of data. It can be installed on any Windows computer, and works as an additional unit similar to a CD-ROM or DVD-ROM. Like a tape of age, Travan 40 used with the recording heads for data storage on tape. These heads have to be cleaned, and Quantum recommends using a cleaning tape.<br /> <p> <br /> <p>1. Turn on the computer. Remove the cleaning cartridge of your case.<br /> <p><br /> <p>2. Insert the cleaning cartridge into the Travan 40 drive, with the metal plate down. Gently push the drive mechanism that pulls and keeps everything in the device.<br /> <p><br /> <p>3. Look at the LED on the drive Travan, should stop blinking and turns off in about 8 seconds. Note that the LED will remain on the cartridge is used more often than not meant to be used and, if so, remove it and put a new cleaning cartridge.<br /> <p><br /> <p>4. Slide the unit Eject button and hold and pull the exposed sides of the car once the disc is ejected.<br /> <p><br /> <p>5. Record the date on the label of the cleaning cartridge with a marker pen so you can track when your Travan 40 drive yet again and how often you use the cartridge.<br /> <p><br /> <p>6. The return of the cartridge cleaning your plastic box.<br /> <p><br /> <p>7. Repeat the process of cleaning every week if your drive Travan more than 3 hours per day, or every month if you use it with less than 3 hours per day. Clean it twice if you have your computer in an area with a large amount of dust, like a room without air conditioning or a warehouse.<br />
on Jun 21, 2011 | Computers & Internet
Cd sony 815 does not play cd
If you mean the Sony Model # ICF-CD815. A.K.A. Dream Machine
you should check the user manual, for troubleshooting instructions:
https://docs.sony.com/release/ICFCD815.pdf
from the manual:
The CD player does not operate.
  • Did you close the CD lid?
  • Did you place the disc correctly?
  • The disk should be placed with the labeled side up.
  • Dusty or defective disc-Clean the disc with an optional cleaning cloth. Wipe the disc from the center out
  • Take out the CD and leave the CD compartment open for about an hour to remove moisture condensation.
It seems to be a top loader system, so a few checks are in order:
  • Check that the disc spins (Insert CD, try to play and open the tray) Be careful, the disc might fly out of the tray!
  • Clean the CD drive lens with a cotton bud and some optical cleaner (camera shops and radio repair shops/techs should have a suitable liquid)
If the unit seems totally broken, take it to a tech or recycle it at a waste electronics depot and get a new one.
Apr 29, 2014 | Sony Under The Cabinet 3 Disc Cd/fm/am...
I can't make the tape progress reliably in my Dymo Omega home printer
sounds to me like a peice of label is stuck and is amking the labels not move. try to look for a small peice of label or label residue in path. clean w alcohol pad
Feb 28, 2014 | Dymo Office Equipment & Supplies
Remove stuck label
THIS IS COMMON FAULT WITH PEOPLE WHO USE LABELS ON TYPEWRITERS. U MUST NEVER TURN THEM BACKWARDS OR U WILL GET ONE STUCK IN MACHINE. THE ONLY WAY TO GET IT OUT IS TO REMOVE PLATEN AND CLEAN THE JAMMED LABEL FROM THE FEED. AND ON SMITH CORONA MACHINES THIS IS NOT EASY TO DO ONESELF.
Mar 18, 2009 | Smith Corona Wordsmith 200 Typewriter
Sticky label
I assume the label is stuck under the platen
the easiest way is to get a rag, wider than the label, dampen it with some solvent, and try to roll it in like a piece of paper. don't use too much solvent, or it will run off into the machine. be careful, it may melt the plastic.
to see if you have a good solvent, stick a label on something it won't hurt, put a little solvent on the label, wait a little bit and see if the label comes off easily.
if you're not careful, you can damage the machine.
or take the machine to a repair shop, the platen is not easy to remove
Nov 20, 2008 | Office Equipment & Supplies
LOADING TAPE INTO A BROTHERS P-TOUCH
I'm on my second machine since December. Neither P-Touch would feed the white tape, the other layers bunch up inside the machine. Called Brother, and they were no help (indeed not much interested in my problem), except to suggest I clean the rollers with alcohol/q-tip. This action did result in the tape feeding, but not properly as I now get an unusable label strip with all three layers, and printing on the clear layer backed by black layer. POS if you ask me; it is going back to the store.
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
Brother P-touch labeling system PT-1750
You dont. This machine was designed to waste your money and raise Brothers profits.
Oct 04, 2007 | Brother PT-1750 Thermal Label Printer
Tapes keep getting stuck
If your tapes are getting stuck, then most likly it is not a cleaning issue, but a mechanical problem. It would be something in the take up supply reel mechanism. Like a bad clutch, take-up gear or idler, and /or a bad or broken belt.
Sep 28, 2006 | Samsung SV5000W VHS VCR
Tascam CD-D1X4 Professional 1x4 16X Compact Disc Duplicator (043774017010) Burner Logo
80 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
