Blank, doesn't boot, and seems to shut down in under 15 minutes.
My gateway W350A(T-Model) seems to have a booting and loading problem, when I start it up absolutely nothing happens but the light coming on. The screen is completely blank, all that is heard is the fan and by fifteen minutes of waiting the laptop would shut down. Unfortunately, I can't pay for any repairing utensils for this problem, considering I'm just a young person who's parents are in a hard spot. I am answering from a iBook G4, can anyone offer me price free supports to fix my problem? Also, prior to this, the BSOD error has occured several times, could that be the problem?
  • 3 more comments
  • zantofire Apr 18, 2009
    No, after I turn it on it's just blank and nothing happens no matter what I press or do.
    So since I cant access ANYTHING is there no way of fixing it?
  • zantofire Apr 19, 2009
    I'm not using a monitor, this is a laptop gateway model.
  • mrninja
    mrninja May 11, 2010
    there is always a way, if you cant get into the bios, then check for power when you turn the unit on.--get close--closer do you hear the fan running? are you sure the monitor is working? sometimes they just go bad without warning
  • mrninja
    can you get to the bios (f2)
My nephew's W350A had the same issue last year. It turned out that the CPU was loose in its socket and not allowing the POST cycle to run. You will need to remove the back cover and the bracket that goes across the CPU. Remove the CPU and clean the pins with a little rubbing alcohol, re-install and you should be fine. Remember to aply a little more heat-sink grease across the top of the cpu before putting the bracket back on. This will help keep it running cooler.
Posted on Jun 21, 2009
Computer won't boot up
You have to give more information about the behaviour..You computer shuts off..when exactly ? Has it passed bios check? Are windows loading or windows screen appears..?Can you open bios setup while booting?
However..shutting off..seems to me that the Power Unit may have failed
Nov 11, 2013 | Gateway Computers & Internet
I bought a new laptop Acer Gateway NE56R. When i start the laptop, it is taking to some page to view the licence for Linpus. If i don't view the conditions, the laptop is shut down after 15 minutes. If...
If the unit is new under warranty return it to where you purchased it.
If not and you do not need Linpus on your unit, boot into safe mode and run a msconfig.
Put a check mark next to the application which you no longer want to load.
Restart your unit and see if you can navigate into windows.
Hope this has helped you.
Jan 31, 2013 | Gateway NE56R Dual Core 2.10GHz 4GB 320GB...
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
Gateway gt4016 desktop, s/n gcm64 110 54982 unit will not boot up, pressing power button, fans starts, yellow light comes on, then shuts down. cleared cmos, pressed power button unit will boot up but...
the cpu could be over heating make sure its secure if you like get some thermal paste from your local pc world put a little on the top of the cpu under the cpu fan and replace fan securely might work be carefull....bonnell
Sep 17, 2011 | Gateway GT4016 Desktop PC
Gateway Initial Boot Up slow Before Windows
isnt there a quik boot option in the bios?,look at your system info in windows,rt.click my computer and hit properties,is your processor speed correct,and your ram memory all there.?should be a number divisible by 64,if its not and your missing 10 or 15 meg. one of your ram sticks is loose or failing,pop them out and reseat them,seems to help some of the time,hope this helps ,let me know more details
Sep 08, 2009 | Gateway 450SX4 Notebook
Gateway 5056 Media center doesn't boot everytime.
did you look on gateways website for a bios update. the firmware on your motherboard maybe corrupt. go here and check since I dont have your serial number... gateway has a java based scanner that might be able to repair it for you
http://support.gateway.com/support/drivers/dlcenter.asp
please rank me if you can
Jun 22, 2009 | Gateway GT5220 PC Desktop
Gateway w350a when turned on wont get past the black screen
gateway w350a T-series HDMI power on but screen stays blank...Its just a black screen. Is there a fix for this?
Mar 31, 2009 | Gateway M305CRV Notebook
Gateway Laptop W350A
what memory board use gateway w350a
May 21, 2008 | Gateway M305CRV Notebook
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
317 people viewed this question
David Payne
David Payne
