Monitor blinking Let me start at the beginning: I changed out a non working dvd burner with a new burner.Everything started up fine.But for about 3 months I have had the following statement come up when I turn my PC on and it begins to boot: Invalid BOOT.INI file,botting from C:\WINDOWS It works and has not really caused any problems,but I got curious and thought maybe the PC was not booting directly from my Hard Drive so I went to the BIOS settings and where it says "BOOT PRIORITY" I clicked on my hard drive and it asked did I want to save my changes and then exit.I said yes and the PC restarted and immediately the monitor light just started blinking.Nothing will come on the monitor.I was told my another person that I probably changed the CMOS settings so I followed his instructions on how to change the jumper on the CMOS pins in order to reset it.That did not fix the problem.He then said to take the battery out of the motherboard and then try it.Once again,nothing.I've checked the hard drive and the monitor by putting them in another pc and they both work fine.He said when it was saving the changes I made it probably glitched.I have also changed out the video card and that didn't work.So what do I do now?
  • 4 more comments
  • cartooncrazi Apr 19, 2009
    The monitor doesn't do anything when connected to the pc.I've tried putting my windows xp installation disc in but nothing happens.I can hear my drive working and all the lights come on in my 3 drives,all the fans come on.But the monitor light just blinks like it's not getting a signal from the pc.As stated,I've already changed out the video card so I know it's not that.
    Before I made the changes it said INVALID BOOT.INI file.After the changes were made the monitor now justs blinks.That's why I can't reinstall Windows or do anything.The monitor displays nothing.
    As far as the rating goes,I wasn t sure how to reply to your solution since there is no reply button for me to click on.I assumed I had to rate your answer and then it would give me the choice,but that didn't work either.I just tried to change the rating but I don't know if it worked or not.
    By the way,I also took a hard drive from another pc and tried it on the pc that's causing the problem and the monitor still shows nothing on the screen,so I know it's not my hard drive that's screwed up.
    Tried both open slots and it still doesn't work.Is it possible when I clicked yes to save the changes that the pc glitched and the motherboard lost whatever it needs to relay the info to the video card?
    Thanks for your help so far
  • cartooncrazi Apr 20, 2009
    I just emailed you.
    I have been told that it's possible my Northbridge chip was corrupted when the pc was trying to save the changes I made and now the motherboard can't communicate with the AGP slot holding the video card.Can that be fixed or should I just get a new motherboard?
  • 272 Answers
Have you tried windows reinstalling? if not, please try as soon as possible.
Posted on Apr 19, 2009
  • 2 more comments
  • Fixer Apr 19, 2009
    you said to be seen...... Invalid BOOT.INI, BIOS settings and where it says "BOOT PRIORITY"............. and now saying monitor light just blinks. are you sure what you are looking for? You have even gave me an inappropriate rating :o
    Can you please check your RAM s? please remove them and replace them tightly . Try unused slots too.
    That should and i hope will solve your problem. Please let me know..if its get solved or not.
    thanks
    there is a CMOS battery near the front connector and down from the ram slots. can you see? That battery is just like a silver coin. there is a clip on one end. press that away from the battery and remove the battery . wait one of two minuets and place that back. it should remove all the setting change made on your bios and will bring back the Default settings.
    mail me if need some instant solution u need... t.mahdee@gmail.com
  • Fixer Apr 20, 2009
    Replacing is the ultimate solution. as nothing is working till , you may consider buying a new one. as, i prefer not to waste money unnecessarily , I would first test the GPU else where if it is ok or not. As the problem started with gpu, it should have the problem.
I have a Sega Saturn with about 15 years. I unboxed it and started to play my games. Everything worked fine until Resident Evil 1. I start the game (everything fine, menu fine, options fine, intro movie...
It sounds like its definitely something wrong with the system. There must be something about this game that the system is having trouble reading correctly. I don't see there being much of a fix for this unless maybe you brought it in to a local game shop and had let look at it.
Aug 12, 2013 | Sega Saturn Console
I have a compaq presario SR2020NX 2005 and there been like around 3 years that I have not been using it, then I decided to turn it on ( started beeping) well I brought everything new ( power-supply...
Rita...Unplug the computer, take your BIOS battery out (make a note of which side is facing up!), wait 15 minutes, replace the battery (make sure it goes in the same way it came out, do not reverse polarity by accident) and reboot. Does that help? If you had this work done on your computer by a service, contact them with this problem. They should have tested the unit before sending back to you.
Aug 10, 2013 | Compaq Presario SR2000 Desktop PC series...
Model 21 ,start monitor and the fan starts and orange lights come on ,then the lights bounce to 100 % and then back to half and then back to 100% real quick and the fan qiuts and heater never gets the...
This sounds like it is going to be a circuit board issue. When you turn it on the blower should start and the igniter will begin preheating the burner. After 3 minutes the burn lights should come on and you should begin to see some flame with a few seconds. The heater should burn on low for about 10 minutes to allow it to become evenly heated before going to high.
Dec 10, 2010 | Heating & Cooling
My Samsung monitor 244T blinked several times and went black. A few days later I rebooted my computer and it blinked twice and went black. Now power light doesn't even go on. Help!
1).check your monitor cable and power cable.search google for how to check if you do not know...
2).change your RAM into another slot and check if u have 2 RAM interchange it and check..i prefer this must be the RAM problem..
normally when u insert any new RAM..sometimes it does not matches.. in this way the blinking can be happened...
3).disconnect all the cables of CD drive and DVD drive and any other except harddisk cables...and start the system with harddisk and without connecting the CD and DVD drive..
4).clean your processor cooling fan..search google for cleaning cooling fan..this makes the processor to reduce heat or apply cool paste to processor..
let me know that your computer monitor works fine with the above steps...."rate"
Feb 02, 2010 | Samsung SyncMaster 244T Monitor
H22L Dvd-Ram reads Cd's not Dvd's.
the lense of the drive become weak.
there two variable resistance under the lense 1 for cd and 2nd for dvd . slightly adjust them and then check again.
it works only ion some cases. otherwise chande the drive with new one.
Dec 01, 2009 | LG (DAD-8020B) DVD-RAM Burner
DVD/CD burner/player does not read, play or burn.
try this go to start-controll panel-system-hardware-device monitor and click the plus sighn by the cd/dvd if it is listed the dirve went bad if not 1 of 2 things will happen 1 right click and clock scan for hardware changes if it still dont reconize it than the drive is definitly bad you will need a new one.
Jun 29, 2009 | Dell Studio Slim-Tower Desktop Computer
Burned DVD video couldn't play
are the videos you are rying to burn store bought
Mar 25, 2009 | Ricoh MP5240A (RICOHMP5240A) DVD+RW Burner
LG L1940HR screen blinks for 1 min. when turning monitor on
some monitors blinks when you have a start up. this usually happens on an outdated video cards. so if it works fine then its ok then. but try checking if you have the latest update for your video card. this happens on an outdated nvidia geforce 7300 go on a laptop runing on windows vista 32 bit. once i updated the videocard, it doesnt blink anymore at start ups.
Feb 06, 2009 | LG FLATRON L1970HR LCD Monitor
DVD Drive does not start
cd opens, but dvd does not open or burns
Nov 24, 2007 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
LG GSA-H22N DVD-RW Dual Layer
Remove, then reinstall the burner's drivers...accordianman
Nov 05, 2007 | LG GSA-H22N DVD±RW Dual Layer Burner
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
