Question about Kitchen Appliances - Others
Stirring arm came off
The stirring arm on my Salton popcorn maker came off and I'm not sure how to reattach it to the revolving center disc.
    President:
  • 1,489 Answers
It screws on. Try clockwise first.
Posted on Apr 21, 2009
The stirring rod fell off. How do I fix this?
The center hub is screwed on. With the popper cold, try unscrewing the center piece. The stir wire sits in a channel under the center piece.
Sep 02, 2013 | West Bend 82306 Stir Crazy® Popcorn...
Do you do popcorn machine 8oz stirring rod please?
Your question has more questions than answers. You choose a Gold Medal 2408 Popcorn popper as your model, but it does not have a 60ktyz motor, the stir rod and shaft are separate from the motor, and you can't get parts for it on ebay.
What model machine do you have?
Feb 19, 2013 | Gold Medal 2408 Popcorn Maker
Where can I buy a replacement plastic nut that holds the stirring rod in place?
Mar 28, 2010 | West Bend 82306 Stir Crazy® Popcorn...
Wire
I had the same problem with mine. Turn the center disk counterclockwise until it unscrews completely and reattach the stirring arm.
Dec 11, 2008 | Salton PCST22 Popcorn Maker
Brown oily leak
The oil is leaking around the stirring-arm-motor shaft -- it needs a new seal. It's not the oil you're using.
Nov 15, 2008 | West Bend 82308 Stir Crazy® Popcorn...
Stirring rod stopped
Hey,
The stirring rod is operated by a motor on the bottom of the popcorn maker, if the rod is not moving, it means the motor is not moviing either. Most likely faulty motor, and it should be replaceable by opening the bottom of the maker. If the motor rotates but the rod doesn't move, something is cut in between the motor and the rod.
Thanks,
Ekse
Aug 07, 2008 | West Bend 82306 Stir Crazy® Popcorn...
Salton Popcorn popper Model# PCST22Y
I owned one of these and it worked for 2 whole months.
It's a popcorn machine, how hard could it be? Make sure the stirring bar it tight on it's shaft, make sure the plastic bolt is tight. Add about 2 tablespoons of vegetable oil, and 1/4 to 1/3 cup popcorn kernels. Turn the machine on. Turn the machine off when the popcorn stops popping, or you might scorch the popcorn.
Aug 01, 2008 | Salton PCST22 Popcorn Maker
Popping plate not heating up
Remember the strirring rod connects to the motor, but the heating element connects via the two prongs in the rear, so the motor can run without the heating element turned on (turn on the base without the plate on...the motor runs fine). Try reattaching the plate...it needs a good connection to the connectors in the back. It should heat up pretty quickly. Also, if you put the heating pad in the dishwasher, make sure it is dry and that the contacts aren't tarnished.
I'm certain over time the contacts will get loose and the popper will stop working, but our is going fine after a year.
Also, be careful not to drop the base...lots of cheap, hard plastic that will break and rattle around.
Mar 01, 2008 | Cuisinart CPM-800 Popcorn Maker
Kitchen Appliances - Others Logo
167 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
