Question about Canon Pixma MP450 All-In-One InkJet Printer
When I try to print,it keeps on saying that my printer is not
When I try to print,it says that the printer is not responding.
  • Bob Kitaji May 11, 2010
    Does you printer show up on the status screen under the control panel printer status?
    Start
    Control Panel
    Printers
  • 68 Answers
Make sure your MP450 is your default printer..go to start menu>control panel>printers...then at MP450 icon, do a right click and choose set printer as default...then try to open up your work again to make sure it is refresh and try to print....see the result...
hope this can help u..n if it is function, please choose it as FixYa!
Posted on May 27, 2009
3 Suggested Answers
SOURCE: Can not print at all.
I found a similar error on a Vista 32-bit OS when I tried to print using notepad. There's no dot before dll.
PSW_Resdll.
I wouldn't suggest simply deleting the printer from the Control Panel's "Printers and Faxes" folder since that will still leave the printer drivers behind.
Try this instead:
1. Make sure you have the installer CD of the printer, and if not try to download it from the manufacturer's website. Make sure you choose appropriately if you're using Vista or it can cause problems. If you don't do this, Windows won't always download the proper driver for you.
2. Go to Start > Programs (or All Programs) > (Printer Brand) > Uninstall to make sure it's uninstalled, and also check it from the Add/Remove Programs (or Program Features).
3. Restart PC.
4. Use the installer CD, or downloaded installer, to reinstall printer.
5. Test printing from different programs.
If after all of these are done and you still have the same problem (unlikely, but hey, anything can happen), you need to call either the printer or computer technician. Most likely the first.
I tried this process and it printer worked fine.
Posted on Apr 05, 2009
seeker5211
  • 1089 Answers
SOURCE: printer will not print. keeps saying
The cover on the right side will slide to the rear. Take it off. You will see a metal door. Power is off at this time!
Grab the door at the left and pull it open. You'll see a memory DIMM. Pull the little silver clips on either side of the DIMM out. The Dimm should release. Take it out. Power up the printer. If you don't get the error, power off. Reinsert DIMM. Power on. If no error, you've fixed it. If error comes back, you need a new DIMM. You should be able to print with out the memory, only slower.
Posted on Feb 09, 2010
My canon mx452 keeps sending a message on screen saying printer not responding.I have run a diagnosis and it says no problem.
Make sure you are getting blank printouts when printing from the printers control panel, not just your computer. If it's printing blanks from both of these procedures, the focus would be on the "Printhead". Some Printheads are easy to remove, sits under the inks. Should be a grey latch you release to get access to the printhead. (remove inks first). Soak this printhead in a solution of windex, about a quarter inch deep, for about 20 minutes, wipe clean with isopropol alcohol and reinstall in your printer and do another alignment / cleaning procedure. If this does'nt fix the issue, you might try replacing the Printhead or retiring this printer.
Mar 02, 2015 | Canon Pixma MX452
I can't print anything on printer, and when I try, it says the printer is not responding. In Printers and Faxes, it says it is ready.
helaineliew,
Sure sounds like you have another printer as the default. Click on start. Then click on control panel. Click on printers and other stuff. See which printer is set as the default. If the Canon Pixma mx340 isn't change it. This should solve your problem.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 13, 2011 | Canon PIXMA MX340 Wireless Office...
CANON PIXMA MX310: printer not responding.
If you go to Start, Printers and Faxes, if it says "Offline", right-click the printer and choose "Use Printer Online." If it says Ready, you should be good to go.
If however there is a problem yet, double-click the Printer there and see if any jobs are in the print queue. You can remove them all buy Right-Clicking and choosing "Cancel All Documents" then try printing a test page. Right-click the printer, go to properties and click "Print Test Page."
If you still have problems, follow up on your question.
Aug 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer says out of paper when the tray is loaded
1. Shut the printer down
2. disconnect the power cable and network cable if you have one
3. wait 5 minutes
4. put the cords back in
5. power the printer back up
Good Luck !!!!!
Jul 21, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Will not print. says printer not responding
Canon i320 does not want to print light flashes green and orange alternatively. Please help. I tried the above, but nothing works
Apr 20, 2009 | Canon BubbleJet i320 Printer
My canon s200sp is not responding, what should i do?
  • Right click on your printer and you will see there an option that says Use printer.. the option you will click on is "ONLINE".
  • After doing that, make sure that the printer is online already.
  • Try printing.
Hope this helps!
Nov 09, 2008 | Canon Office Equipment & Supplies
PROBLEM WITH PRINTING
You have problem with your fuser in printer, as the message says. Having the powercord straight to wallsocket, no extensioncables? Try take it out and reinsert if it's removable. otherwise you have to buy a new fuser.
Nov 03, 2008 | HP LaserJet 5200tn Printer
Printer stopped printing says not responding
Just go to printer icon on tray after print attempt, and clear print queue, it may be confused with unsent jobs. Clearing this should help. Try turning it off and unpugging it, then replugging and on again to reset itself. Failing this, try a compete unistall and reinstall. Cheers lilacgerry
Jul 31, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer doesn't respond to computer
there were many instances why the computer says "printer is not responding" either it is not configured correctly. for a start..
try this go to start- printer- right click the desired printer- open up properties- then click print test pages-
if it does print then it should work on all platforms, if it doesnt then you might have installed the wrong drivers.
try this first
Jul 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon Pixma MP450 All-In-One InkJet Printer Logo
255 people viewed this question
old marine
old marine
