Question about Yamaha Electric Guitar
Change the strings on a
I have a
ltd alicks trillo 200 flying v with a floating bridge
the stringes are wering out and idk how to replace them
  • 73 Answers
Http://www.youtube.com/watch?v=A_q2wleWRvw
Thats a youtube video to help you out man, I bought 2 mavericks and 3 ibanez before I knew how to change the strings!
Posted on Apr 23, 2009
My boy has an esp ltd ax 150 bass which has broken E strings at the bridge since new almost 1 a week the bridge was modified by a Luthier which worked for a small amount of time then the problem came
You friends bass has a burr on the saddle. take a small fine file and go along the pacth of the string...Go over the saddle and slowly file lightly..This should get rid of your problem...take it to a service center if you arent comfortable doing this
Apr 08, 2013 | ESP AX-414 LTD 4-String Electric Bass...
Put new string in a hohner steinberger bass very hard to turn tuner to pitch
You have stripped the threads on the string retainer part of the bridge adjusters. You will have to have it rethreaded with helicoils or buy a replacement which is $39
Nov 02, 2012 | Hohner B2AV-CRS Headless Left Handed 5...
How to change the strings onthe epiphone professional deluxe mandolin
You can slide the silver plate straight back by gently pushing it from the top with your fingers. Once it slides off you will then be able to see the hooks that you put the new strings on (loop end strings). Once strings are tightened, you slide the cover back on the same way you slid it off. There is a small piece of felt glued to the cover. Be careful not to knock it loose when you are putting the cover on.
One other tip, change one string at a time instead of pulling all of them off at once. The bridge will come loose if you take all the strings off at once (it is not glued to the mandolin).
Feb 17, 2012 | Epiphone MM-50E Professional Mandolin
I bought a used Fender FB55 banjo, it's appearance looks new. I'm new to banjo's but not guitars. I really didn't know how a banjo should sound. I practiced with it as is, I noticed that I...
Check the neck to body attachment. There may be a problem there, especially if it has been strained in the past. The fact that the strings were so high when you got this would indicate there MAY be a problem with the neck attachment or the body where it attaches. Word of caution: Investigate how repairs are done on the instrument before attempting a fix. Using wrong materials can permanently disable an instrument. Banjos DO go out of tune easily, depending on how they are played. Another thing to remember is that strings are within about 10% of breaking when in tune on stringed instruments.
Sep 10, 2011 | Fender FB55 5-String Banjo (Refurbished)
How to change strings on an esp ltd alexi 200 guitar
http://www.youtube.com/watch?v=A_q2wleWRvw
heres 1 of many youtube videos that explain the way to change strings on a floyd rose. first try might give you a lil trouble but you'll get the hang of it. Good luck!
Aug 31, 2011 | ESP Ltd Alexi 200 Electric Guitar
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
Washburn guitar B and high E string sound real buzzy-tinny. am fretting it clean. It just started doing it. Any Help?
Probably time for string replacement !!! They do go bad...
Get a set and try the E string... if it fixes that one, change ALL the strings at one sitting, but do them one at a time and tune each as you go... this keeps the tension and minimizes the interaction when you do the final tuning.
Feb 27, 2010 | Washburn Idol Series WI18QT Electric...
New flying v, 3 strings make rattly sound near end
Are the strings hitting the frets and making a buzzing sound or is it actually coming from the bridge? Make sure the saddles on the bridge are secure. If the buzzing is caused by the fret then adjust the bridge height and/or truss rod. If the buzzing is coming from the bridge and cannot be cured it may be worth investing in an aftermarket bridge.
Jan 08, 2010 | Coffin Case 300VX Flying V / EXplorer...
My sx prob is with intonation, I set it up with the tuner on the 12th fret etc, but when I think I'm done I play a few chords and D or A is out. Also my G string is almost way back into the bridge with...
If you have a floating bridge such as a flloyd rose you will have this problem unless you followed the instructions for changing strings. The instructions are on the net for various manufacturers. Ibanez, BC Rich and flloyd rose all have good instructions. There are other good sites to explain bridge and intonation adjustments. You have to remember that new strings have to stretch in before they can be tuned accurately. My son has a Jemm that he does one string at a time and lets them sit. You also have to take string guage into account. Different guages tune differently especially if you are mixing the guages. http://www.fretnotguitarrepair.com/Electric_Guitar_Intonation.htm is a good place to start. Hope this helps.
Jul 16, 2009 | Music
Blinking peg white when tightening
idk how i did it. i kinda just clipped the strings a bit more and it worked :)
Apr 02, 2009 | Gibson Robot SG Special LTD Ebony
Yamaha Electric Guitar Logo
111 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
