Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
TV banged litte in a move
Hi my sony tv was banged litte in the move. Now when we plug the cable in the blue screen comes up, but nothing else...like the regular picture. But if we switch to different mode the DVD player works fine. Can you tell us what could be the problem?
    Scholar:
  • 87 Answers
Take the back off the set and check for any cracks on the PCB near the tuner. The tuner is where the cable hooks up. Make sure the threaded connector is tight. The set defaults to a blue screen when there is no signal.
Posted on Nov 06, 2007
I am getting a blue screen whenever i turn on my ps3. Ive tried resetting the system several times and can not find the solution. Audio works just a blue screen on the t.v.
You said the sound works but you get a blue screen on the TV, check your TV if it is set properly.
Make sure the Input is correct on the TV to shoe the Video coming from the console and check if the cable connections are properly connected to the TV and the console video output and input.
Also try it on a different TV to see if the issues is with the TV or the Console itself if on a different TV and the issue is still the same the issue is the Video output from the console but to check further more try a different cable, borrow one or maybe buy a new one just to see and eliminate possible causes of the Blue screen issue.
I hope this helps.
Aug 01, 2011 | Sony Playstation 3 (PS3) Console
White noise from the line out only, picking up usb noise
Hi thesuther,
had often these problems and I solved them by:
- (first) check the (USB) cables ... since I never bought 2 EUR cable
- check interference (unplug active devices on by one and see which one is cosing it) TV, radiator/heater/cooler, some lights as well, , some fan,
- move your amplifier to another place ...
- else, is litle advanced so I prefer that someone with more knowldge discuss it ...
cheers
Apr 29, 2010 | Tascam US-122 USB Audio/MIDI Interface...
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
The picture is visible but there is an opaque blue area in the picture on the left side of the screen
Sony bravia
This blue is caused by magnetic fields. Either the speakers of tv is faulty or demagnatziser not working. Switch of tv and remove powercord from wallsockets. Leave for about 10 hours and plug in powercord and switch on. if demagnatiszr is working the blue will be gone. if not have youre tv demagnetized
If hometheatre or radio speakers are closer than ½ meter this could also generate coulouration of screen. move speakers further away. If tv is on and and being moved your static electricity can also cause this. So switch of if if you move your tv.
Aug 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Blue screen only
double check the input, the simple way is using a good DVD player and good A/V Cable. plug in the A/V cable in DVD A/V output, then plug the other plug into TV A/V input. Then set your tv to AV input. if nothing comes out even though the dvd player is playing. The TV AV switch maybe damaged.
Jun 02, 2009 | Prima C2012 TV
Blank Blue Screen
If you go to menu do you get that on the screen?
Nov 21, 2017 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Nov 20, 2008 | LG 32LB9D TV
Blue tint screen in video mode
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
