Question about ASUS A7V400-MX Motherboard
Motherboard beeps my computer turns on but i do not get a screen i have tried a new graphics card but all i get is a long beep with a 7 second interval bafore the next beep
  • 272 Answers
One beep represents the memory ( RAM ) problem. You may have accidentally touched the RAM that caused the problem. please remove the ram(s) and place them again tightly.
this should solve your problem.
Posted on Apr 18, 2009
I have a Acer Verton E430 Desktop. Suddenly upon restart after the initial beep and Acer splash screen returns to restart with one short beep and process continues on and on.. Advise how to solve.
One short beep can be DRAM refresh failure.
  1. Remove RAM memory, Graphics card, other Plug-in cards, and Drive cables from your mainboard.
    Only CPU + Fan + Power cable are installed on the mainboard.
  2. Power on the PC, and listen to the beeps:
    • no beeps => Power supply, CPU, mainboard or BIOS is most likely defective.
    • some beeps => remember the beeps and next step.
  3. Power off the PC, and insert the RAM memory.
  4. Power on the PC, and listen to the beeps:
    • no beeps => RAM incorrectly installed.
    • same beeps as before => RAM is most likely defective.
    • beeps have changed => next step.
  5. Power off the PC, and insert the Graphics card.
  6. Power on the PC:
    • some beeps => Graphics card is most likely defective.
    • blank screen =>Graphics card is most likely defective.
Dec 02, 2014 | Acer Computers & Internet
I plugged my new video card in pci express socket, turned on computer, I get 4beeps 2 beeps 3 beeps 3 beeps and no picture.
what is the make of the motherboard you are using?
does the card need extra power supply plugged into the card?
tried another card to see if the new card is faulty?
Jan 18, 2011 | ASUS EAH5450 SILENTDI1GD2 graphics adapter...
Everytime i try to turn on my computer it beeps continuously i just installed new ram and a graphics card took them out put original back in and still does it.
The particular issue of beeping continuously is the RAM you need to check if the RAM is correctly installed. Make sure that the RAM you have install are compatible to you RAM slot. It will cause continues beeping and will not display the monitor.
Another thing you should check is the graphics card. Check this also if it is correctly installed. Install also the graphics card installer.
Dec 01, 2009 | Mach Speed Viper K8M8MS Motherboard
Long beep followed by 2 short beeps. Then computer hangs. What is the issue?
I do not know what model laptop you have, but generally IBM beep code of 1L, 2S and a blank screen lead to sequential replacement of:
1.System Board
2. LCD Panel
3. DIMM
This is per their field service manual. In standard desktop PCs this code would indicate a bad or mis-seated video adapter. (hence a laptop system board).
Aug 05, 2009 | Computers & Internet
The screen doesnt come up
The beeps[s] usually signify either improperly seated/bad RAM, or improperly seated or bad graphics card. Try reseating these and reboot, if it still beeps then try removing the video card & reboot. If it does boot that way then you know it is a bad video card rather than bad ram. Hope this helps & please remember to rate my answer. Thanks.
Jan 22, 2009 | Gigabyte GA-K8U-939 Motherboard
Ga-k8nxp-sli problem
you have a hardware fault try removing 1 set of memory test if not work try different video card suspect one or other wrong
Jul 24, 2008 | Gigabyte GA-K8NXP-SLI Motherboard
Graphic card
Do you have the 6-pin PCI-E power connector attached to the new video card? If you do it's possible you power supply is insufficient and may need to be upgraded.
Dec 18, 2007 | ASUS P5GV-MX Motherboard
955X7AA-8EKRS2 doesn't start
your pc doesn't give display this is the problem of RAM or GRAPHICS CARD. you must clean the RAM and graphics card with a soft cloth and then affix them
Dec 13, 2007 | Foxconn 955X7AA-8EKRS2 (683562472159)...
My computer (emachines T5212) beeps at me
These are called beep codes and there should be a pattern of long and/or short beeps which will repeat. Once you identify the pattern we can help figure this out for you.
Jan 11, 2007 | E-Machines eMachines Desktop PC
ASUS A7V400-MX Motherboard Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
