Question about Garden
Hello. My John Deere mower has started surging at an idle. I cleaned the gas tank and replaced the fuel filter but it still surges at an idle.
  • sandmancoop May 19, 2009
    My mower surges at low idle. It sometimes skips at high idle. I replaced the fuel and air filters. replaced the fuel pump and sparkplug. Dropped the carburator bowl and cleaned it. Nothing helps.
I have a john deere 420 rider. It would surge at a higher speed. It is a hydrostatic and there were 2 bolts on the transmission that were loose. now it runs beautifully smooth,
Posted on May 04, 2009
No answer... but I have the same problem I have a x320 with 15 hours on it. just took it in sat. They will look at it Monday but told me it probably won't be covered under warranty because they can't control what gas I used. and that's B. S. THEY TOLD ME I SHOULD OF BEEN USING NON Ethanol gas......
Posted on Apr 25, 2016
THE BABY BOY
Posted on Sep 25, 2011
JD lawn tractor starts hard, can only idle and gas drips out of tube on carb until warm,it runs for 20 mins. then starts surging and dies,wait awhile, then starts.
try removing the carby and cleaning out the needle and seat area
the float pushed the needle up into a seat that can get hair , grass bits , dirt between the needle and the seat and then the fuel becomes uncontrolled and flows out the carby
I suggest a clean , blow out oul of the jets and work from there
May 13, 2016 | John Deere Garden
John Deere L111 from 2004 surges in idle. Have replaced plugs, fuel/oil filters, fuel pump. Still does it.
Cleaning the carburetor is a good starting point. There is two versions the Briggs that were used on this mower. One had a single barrel and the other had a two barrel version. Both were Nikki carburetor that main jets that are held in place by tiny o-ring that shrink causing the jets to leak extra fuel causing surging.
Aug 11, 2014 | Garden
John deere lt190
If fuel is getting into the oil, I would say the needle and seat or float in carb is not stopping fuel flow. I would check carb again and adjust float level. Change or install an inline fuel filter too. Surging is almost always carb related. If problem persists after checking carb again, check governor springs. If they have been bent at all after removing carb, they can be bad. If you replace new governor springs and surging still exists, try doing a static setting on carb/governor. If your unit has an oil/centrifugal governor, move governor arm in the direction that opens throttle valve in carb all the way, hold in place, loosen nut on governor arm and grab small tang that goes inside engine and turn in the same direction you moved governor arm, rotate this until it stops, hold in place and tighten nut on bottom of governor arm. This is called a static/factory setting. Make sure throttle cable is in high position when doing this. Let me know if you have any questions. Good luck!
Oct 22, 2013 | Garden
John deere tractor wont take up throttle
try some lucas gas treatment. may have something to do with the float in carb. Might replace it and try.
Jun 20, 2013 | Garden
Engine surging
Drain the gas replace fuel filter then see if that helps if not clean the whole carburator should stop it.
Jul 29, 2017 | Tecumseh Lawn Boy Push Mowers Insight...
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere GX85 Riding Mower engine surges
did you drain the gas before putting it away last season? If not, I would drain all of the gas and put in fresh gas, also replace any in line gas filters
Apr 06, 2010 | Garden
09 JD X 340 27hp Kawasaki eng\ surges
Hi
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Sam
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Cub Cadet 2165 engine surges and eventually stalls
Replace the fuel cap!!! The problem is that hte fuel cap vents from it's underside. In so doing it sucks up all of the grass debris and dust that hte mower deck kicks up and the vents get clogged up. As the engine uses the gas, it builds up a vacuum in the tank and the gas can no longer flow from the tank to the engine.
Jun 15, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
1,808 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
