Question about HP Officejet 5510 All-In-One Thermal Printer
How to change gears
Can you literally show me how to change the strip gears on my printer please.
Gears normally is situated in the ink waste bin so what u do is disassemle the printer go to the waste bin remove the old gear n replace a new one
Posted on May 26, 2008
Hi my printer laserjet is showing error 22 how do I fix that please
Try unplugging the printer from the computer(leave the mains Plug connected:-) print 4or 5 test pages then re-connect the printer. This should do it.
Oct 06, 2014 | HP LaserJet Pro M1212nf MFP -...
It says i have a automatic alignment problem it shows i have ink i have'nt changed the ink since i brought the printer.
It could be that the cartridges are not seated properly in the cartridge carrier or the encoder strip got unseated from its position. Please follow steps below to fix the problem:
  1. Open the printer cover.
  2. Remove both cartridges from the printer.
  3. While the printer cover is open, check the cartridge area for a loose encoder strip (transparent strip).
  4. Close the printer cover.
  5. Unplug and re-plug the printer into the power source to reset it.
  6. When the printer turns on, re-insert one cartridge first.
  7. Close printer and check for any errors.
  8. If no error appears, reinsert your other cartridge.
  9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 25, 2011 | Lexmark Z2420 Printer
I get a service error 5100. What is this and how do i fix it? i changed ink cartridges and then got this error. it seem the cartridges only fit one way because i tried to reverse how i put them in.
Hello !
Service error 5100 is a carriage error. Be certain that the strip is remove from the cartridges. Check the timing strip for contamination (plastic strip about 1/4" in width)
Check for obstructions. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt. There could be paper caught underneath the rollers. Check VERY thoroughly.
Hope this helps.
Oct 12, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I open the case to change the print cartiridge, but the cartiridge holders remain on the left hand side, and will not come to the middle for me to change. and the green on switch keeps blinking while it is...
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
Oct 02, 2009 | Lexmark PhotoJet Z705 InkJet Printer
Printer labels do not advance when print is hit
CAUSE: my guess would be a stripped gear or a lack of prssure on the "pinch wheel" which would cause a loss of traction on the paper feeder.
SOLUTION: 1- change the stripped gear (if it's stripped)
2- add a layer of adhesive tape on the loose pinch wheel (if it's loose)
both solutions require to open case (to access loose wheel or stripped gear). To determin what the probleme is, try to run a print and try to move or pull gently on the lable ribon while in function. Two possible outcomes are that the gear will only "hook" in some areas if it's stripped. If it's loose the paper will only move while pulling on it.
Jul 24, 2009 | Brady ID PAL Thermal Label Printer
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
there could be three reasons for this problem
1)the printer cover is not properly closed.
2)either any of the cartridge is faulty.
3)or there is literally the paper jam in the at the back of the printer there is a assess door just remove that door and you can see inside any paper jam.also look for any minute tiny pieces of paper blocking the gears to forward and it shows paper jam.
Oct 13, 2008 | HP Deskjet 2360 InkJet Printer
Canon Multipass F60 error
Encoder strip is the transparent strip which behind the cartridges carrier2b85ffb.jpg
A: Encoder strip (semi-transparent gray strip)
B: Carrier belt (black and brown toothed belt)
Please open the cover and check if the carriers is coming to the center ,if not gently pull the cart carrier to the center and then power on the printer , be carefully with encoder if its damaged then you cannot use the printer...
Good luck...
Oct 13, 2008 | Canon MultiPASS F60 All-In-One InkJet...
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
147 people viewed this question
Ben Johnson
