All in one is connected to an ansewering machine and telephone and dose not always reconize an incoming fax. I never had this this problem in the past and have even purchased and installed a ne ansewerin machine. It dose reconize a fax when i disconnect the ansewering system and connect the all in one directly to the wall outlet.
  • melephillips Apr 19, 2009
    If what your saying is the problem I don't think it would work part of the time.
    New Friend:
    Problem Solver:
  • 7 Answers
Putting up an answering machine in an all in one means having two output at the same time. (1 fax and 2 ans machine). You need to have separate lines for each. A fax line can not accommodate two machines at the same time.
Posted on Apr 19, 2009
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Connecting Linksys wrtu54g wireless router with Linksys SPA 2102
If you want to receive "incoming" telephone-calls:
ADSL modem <---> Linksys SPA <---> wrtu54g <---> wired computer
and Linksys SPA <--- telephone-line-1 --> telephone hand-set
and Linksys SPA <--- telephone-line-2 --> FAX machine
or Linksys SPA <-- telephone-line-1 --> mechanical telephone-splitter
with telephone-splitter --> hand-set
with telephone-splitter --> FAX
Mar 19, 2009 | Linksys Wireless-G Broadband Router
On the m9516 what is the fax switch on and off used for?
The Fax Switch
The Fax Switch feature allows you to have two telephone numbers on one incoming line.
There is one telephone number for the line and another telephone number for a Fax Switch peripheral (e.g. fax machine).
To use the Fax Switch, you must subscribe to your telephone company for Distinctive Ringing†. The telephone company will then provide you with an additional telephone number (for your Fax Switch peripheral) which will have a slightly different ring. The 9516 will use the two ring types to determine whether an incoming call is for the telephone or the peripheral. The peripheral should be set to answer after three or more rings.
Note: If Long Distance Ringing† is available in your area, long distance calls will be sent to the Fax Switch peripheral. Also, you cannot use the Fax Switch feature and the Special Greeting feature at the same time. The 9516 must be configured so the Fax Switch peripheral is connected to pins 3 and 4 of jack number 2. See Connecting an optional fax machine or modem on
page 4 for more information.
Note:
If you subscribe to your telephone company for Call Waiting services, your Fax Switch peripheral may lose data or get disconnected if someone calls while your fax is receiving data. We recommend that you do not subscribe to the Call Waiting service from your telephone company if you are using the Fax Switch feature.
Jan 30, 2009 | NorStar Meridian M9516 Phone w/ Digital...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
I have just puchased a new Fax machine, I only have one telephone line but when I sent the machine to Fax/Tel the machine takes over and keeps ringing until i press tele/Rev..I want to receive incoming...
I always setup my faxes with FAXONLY mode,I set the incomming ring to "on "and ring count to "7".
And check wat is your remote rx number-with that number you can dail it and it will go to fax automaticly.
Nov 04, 2008 | Brother Office Equipment & Supplies
Telephone rings only twice
No. Fax machines are designed to have their own dedicated fax lines.
Some newer models, tho, allow you to set NUMBER OF RINGS.
Oct 30, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
How to not print faxes after hours
simply go into modes Fax/telephone and select telephone mode only instead of fax/telephone mode there is really no way to set the fax to not take faxes after hours automatically as it is designed to receive telephone calls and faxes as the machine reconizes fax tone.
the only disadvantage to doing this is you will have to change mode on a daily basis back to Fax/tel Mode during work hrs and back to telephone mode after hrs or simply uplug the phone cord going to the fax after hours
Jan 07, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Incoming fax
THE PHONE LINE HAS DISTURBANCE ,PLEASE CALL TELEPHONE COMPANY  TO CHECK...
HAPPY FAXING
OMNIPRESENT
Oct 15, 2007 | Samsung SF-531 Plain Paper Laser Fax
37 people viewed this question
k24674
