Question about Philips 25PS40S 25" TV
Tv problem it powers up but pictures does'nt pass through.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
If light is not there check hor. section if it is ok check video section or luminance section. provided power supply is ok in your tv.
Posted on Sep 19, 2007
Have purple on my tv screen
Posted on Dec 24, 2007
    Problem Solver:
  • 9 Answers
OK sorted the problem on my set. Replaced the capacitor ref: 2455 on main board it is a 47uf 25v but i was told a 35v will work as well? But mine is a 28pw6506/05
Posted on Nov 17, 2007
SOURCE:
Red tint on PROTON TV picture
did u go through the menu and check for the contrast and tints?
Mar 03, 2012 | Proton NT-333 31" TV
TV turns on normally and picture appears with sound. However after a few minutes there is a short static sound and the picture goes blank. I have unplugged and the tv and reset the surge protector. The...
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
I hope this will help to solve the problem.....
Aug 08, 2011 | LG 32LB9D TV
No picture, on off button keeps going on and off buy it self with no picture, can't bring up menu.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
I hope this will help to fix the problem of the television...
May 21, 2011 | Televison & Video
Connected to pay TV.Picture goes off but sound remains.Switch TV off and after 20 seconds most times picture returns.TV is Phillips Cineos 6 yrs old
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Take care in solving the problem....
May 10, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
Model: CM21AF8A
the picture is produced by the following,
check the power supply, making sure that a high voltage is produced of about 90-110 volts, which later triggers a line transformer to oscilate.
a power supply is suppose to be checked expecialy semi conductors and diodes, also fusible resistors be checked make sure that the switch is okay power is passing through it.
Apr 12, 2009 | Sanyo DS32224 TV
Cannot get a picture
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent. If the picture does not return, then you have a more serious problem, that requires the attention of a TV repairman.
Jul 05, 2008 | Televison & Video
Problem of COBY DVD 283 player
return it for a different one
Jul 01, 2008 | Coby DVD-283 DVD Player
No picture
Try a "hard restart"', which simply means unplugging the power cord of your TV, and replugging it after 4 hours have passed. This technique helps to reprogram the electronics of your TV.
Hope this suggestion works for you.
Jun 05, 2008 | Mitsubishi VS-60607 TV
Sound/ no picture
dats dfine...switch off ur tv...instead of surfing u go dierctly to an electrician and get it repaired..delay makes u loss nt more than dat....
Jan 08, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Not playing DVD
i have coby dvd 283 player , its new but i don't know why it is nt playing ..........when i start the power button and insert disk , then on my tv on right hand upper side of the tv only a picture of the disk rotating round is seen .................pls help me out what shall i do
Aug 23, 2007 | Coby DVD-283 DVD Player
Philips 25PS40S 25" TV Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
