Question about Ruud UBHC Air Conditioner
Ruud Silhouette II won't light
I have a Ruud Silhouette II and the HSI is cracked for sure. I can fix thishowever, I am currently stuck in a blizzard and wondering if it trulyis unsafe to manually light the burner as the instructions say? It's getting very cold...
Please help!
    Guru:
  • 1,524 Answers
Yes
Posted on Apr 26, 2009
I have a Ruud Silhouette II plus LXE that the hsi is energizing when the thermostat is in the off position. We have not used the heat in months only the A/C.
If the inducer motor is not turning on, it is not getting a call for heat and the hsi should not be energized. If it is energized without a call for heat, then the circuit board will need to be replace in the furnace...it has stuck contacts on the hsi relay.
Jun 26, 2016 | Ruud Heating & Cooling
Ruud Silhouette II has power but nothing else.
Sounds like there is a secondary fuse protection, or some wire came off. Did you check for ground?
Dec 03, 2014 | Ruud Heating & Cooling
Rudd silhouette ii blower
Send direct power to the blower by bypassing relay . See if motor runs
Jul 19, 2017 | Ruud UBHC Air Conditioner
Heater won't turn on even with a good HSI
Remove at least one of the wires going to that solenoid on the gas valve. Check for continuity between the 2 legs of the solenoid. If you cannot get a reading then you have a bad valve. If you indeed do have continuity start the furnace and see if voltage is going to the valve. If you have no voltage going to the valve then you could have a bad board. If voltage is going to the valve then the gas valve has failed internally or you ain't paid the gas bill. LOL.
Jan 06, 2012 | Heating & Cooling
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Jan 13, 2009 | Heating & Cooling
Flashing amber lights
it means that the flame sensor is not sensing a flame. If the flame is present and nice and blue the flame sensor is probaly dirty. Remove the flame sensor and lighty sand it with sandpaper.
Dec 25, 2008 | Ruud UBHC Air Conditioner
RUUD Silhouette II
You will need to let the indoor fan run for several hours to defrost the indoor coil. it may take 12 hours to defrost you'll know when it's clear when the vents are blowing like usual again. Then run the unit for 5 minuits and check the large copper insulated line going to the outdoor unit. is it cold? if not you need a refrigerant charge. If it is then make sure never to run the unit below 70 degrees and check your air fliter and return duct for blockage of possible collapse. Also you may have a dirty indoor coil chac that and clean the outdoor one as well.
Oct 05, 2008 | LG LM-2430C2L Cool Mini Split Air...
Ruud UBHC Air Conditioner Logo
976 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
