Question about Kenmore 24 in. 16222 Built-in Dishwasher
Dishwasher dishes not clean
Dear Mr/Ms, We have a kenmore elite stanless steel dishwasher. It is around 5yr old it is not getting all of the dishes clean, some time leaving water with debree on the water left on the bottem of glasses/cups. We had this problem before and I now know that at our chopper needs cleaned. I can get it apart until I get to the housing unit? that last big part that covers the whole bottem of the dish washer. I know that the chopper is under there HELP PLEASE! Our water is very hard also, leaving a build up of hard to remove white/tanish color residue LCR works ok, but you still have to scrub for an hour or two any sugestions? Thank You And Have A Great Day!
  • 6 more comments
  • taylored04 Sep 09, 2008
    dishwasher is not getting dishes clean most of the time. havent tried anything yet not sure what to do
  • Anonymous Sep 16, 2008
    My dishes on the top rack are not getting cleaned properly.  The bottom rack is fine.  There is nothing blocking the blade from spinning.  I can't find anything wrong.
    Thanks for your help
  • davee60s Sep 22, 2008
    Dishes on top rack don't get clean. Arms rotates freely, not plugged, drain loop is in proper location. Water pressure is normal (we're on a well, 45 min 60 max psi).
  • Anonymous Dec 07, 2008
    I pried up a part of the cover over the bottom of the diswasher. Underneath is caked with residue. If I could get the cover off, I could clean it out. this residue looks exactly like what is caked to the dishes.
  • lvhal Dec 09, 2008
    What is meant by making sure the salt is topped up?
  • Anonymous Dec 19, 2008
    the unlock sysmbol will not turn off, dish washer isn't functional.
  • tinlac Dec 28, 2008
    I have a kenmore elite dishwasher as well and am having trouble with it. The drain going into the circulation pump cloggs up and then it doen't clean the dishes properly. Something as tiny as a popcorn seed with plug it up and we have to tear the inside of the dishwasher apart to rectify. Is there any solution to this other than prewashing everything?
  • sannyjo Feb 10, 2009
    Kenwood Dishwasher is'nt showing any error codes but the dishes are not clean
  • 318 Answers
First of all to remove residues from your d/w...what will work to remove the scale and soap residues is called "d/w magic". it comes in a plastic square bottle and you can get it at any grocery store, lowes, or sears.
you just remove the cap, put in the top rack and run a full cycle with the water heat boost option and it will clean out almost any residue from your unit. if it is really bad you may need to repeat this 2 times.
then in the future use dry powder soap, not tablets, fill both cups only about half full, use the normal cycle with the water heat option. also make sure the rinse dispenser is full with jet dry or similar product. then you should not get the residues returning.
after you have tried this then you should brush off any food particles before putting the dishes into the unit. do not assume the d/w will "chop" up any food left on the dishes. they are designed to chop up soft food items, but they also will get plugged at the same time. so its best to just brush the dishes off first.
next is if you still have washing problems, then make sure the unit is filling up with enough water. after you start a cycle, let the unit run for about 2 minutes, open the door and see if the water is just below the level of the heating element. thats how much water they need to circulate properly.
i will reply back if you want to know more.
good luck tom
Posted on Dec 31, 2008
  • 209 Answers
I am a retired appliance engineer of 20 years, (and whats a chopper), this problem can be easily improved maybe totally rectified, by making sure the salt is topped up and use rinse aid, make sure all the food catch filters are cleaned out and the waste outlet is also cleaned out, make sure blades are free to rotate and holes are not blocked, these are easy to remove and clean they just unclip. there is no need to dismantle the appliance hope i have helped , if so please rate me,
Posted on Sep 18, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Www.dishwasherfilter.com has a great new product on the market just for this problem. it filters the water going into your dishwasher leaving your dishes spot free every time. it has a money back guarantee and is very affordable. you will love this product. www.dishwasherfilter.com
Posted on Apr 02, 2009
SOURCE:
The dishwasher soap in my kenmore elite dishwasher is not dissloving and as a result my dishes are not getting cleaned. any suggestions?
Check to see if it is filling with water and not draining it right back out. Give model number so I can look for a diagram to repair. Just fixed mine as it was doing the same thing.
Dec 06, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Keep getting a white film on all my dishes, not cleaning properly.
Check the temperature of the water. Should be 120 deg. Also are you using powder or liquid? Liquid dissolved a lot quicker that powder. So liquid is actually better to use. Try running the hot water at the sink until it gets hot before running the dishwasher. Also you may want to try mixing half cascade liquid and half lemon shine.
Nov 14, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The water seems to not be hitting the top row of dishes and the dishwasher has gotten louder, end result not cleaning the dishes
Best to chck the water pump which could be partially blocked and not sending water to the top spray feed.
It would be helpful to have the full model number in order to identify the part numbers etc.
Sep 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
My dish washer is only a few years old the top shelf hardly ever gets clean has food splater inside all of the cups
Typically when your getting poor wash results the filter on the pump is build up and wate ris having a hard time circulating through the pump. This tip i wrote will assist you to take apart the pump to clean the filter http://www.fixya.com/support/r10292354-whirlpool_kitchenaid_kenmore_diswasher
GENE
Sep 09, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore elite model 665 17263402 The top rack is not cleaning the dishes. The bottom rack is cleaning fine. What is causing this and how can I fix it? Please help.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 16, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
New dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Sep 06, 2006 | Kenmore 13869 / 13864 / 13862 Dishwasher
Kenmore 24 in. 16222 Built-in Dishwasher Logo
1,758 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
